AE86 T series diff questions
Postby Stealer Of Souls » Thu Jul 05, 2007 4:08 pm
Okay.
One.
Are the T series known for having a crown wheel and pinion "weakness". I have just worn out a crown wheel and pinion in my T series rear end. The original one in the diff was worn. The first second hand replacement didn't last long (was a little whiny to begin with), and the latest one did better, but is now also a bit goneburger...
In all three cases is seems that the crown wheel and pinion have worn the top hardened surface away and are now grinding.
Two.
Are all RWD final drives helical cut? Why can't the be straight cut? Especially if being used in a more heavy load situation.
Three.
With my Crown wheel and pinion goneburger I'm faced with something of a decision. The second part of my problem is that one axle has a slight bend in it. Just enough to be a pain in the A.
I'm faced with the thought that perhaps i shelve all the current bits for my other car and replace the guts with the late model gear.
Will this work. I have an early model housing and want to put all late model gear on the inside.
Is this a definite 100% guaranteed straight swap. Just buy the late model LSD, axles, and bearings and put it in? Or do you need to change other fiddly little bits?
'86 AE85.5 Levin
Stealer Of Souls
Postby Mr Revhead » Thu Jul 05, 2007 5:46 pm
1: any diff will if not set up right. the T series is no different. they are known for wearing fast if not getting enough oil, just like anything.
2: noise, strength. helical = more surface area meshing
3: housing is the same, so yes.
Postby Burning Angel » Thu Jul 05, 2007 7:13 pm
afaik helical has less surface area in contact at any one time.
although there appears to be more contact area only a small portion of that is contacting at any time which is why their quiter. straight cut gears contact along the whole length of the tooth and are hence noisier.
im pretty sure this is right but feel free to correct me(or maybe im interprting #2 wrong)
Burning Angel
Postby Stealer Of Souls » Thu Jul 05, 2007 10:43 pm
Burning Angel wrote:afaik helical has less surface area in contact at any one time.
This is my understanding... It just interests me that no one makes straight cut crown and pinions.
If I've manage to have three sets of crown and pinion that suffered the same fate...
Are the AE86 race cars suffering the same fate?
Revhead wrote:1: any diff will if not set up right. the T series is no different. they are known for wearing fast if not getting enough oil, just like anything.
This diff was set up by some very reputable and trust worthy people. And neither my mechanic nor his diff person can see why it would be suffering oil issues.
All in all I'm just trying to make sure that my best option is to just get a replacement crown wheel and pinion, and not search for some "custom" arrangement.
'86 AE85.5 Levin
Stealer Of Souls
Postby frost » Thu Jul 05, 2007 10:46 pm
no its the other way round. helical has 1.5 tooth touching at any one time and straight cut only has 1 tooth touching.
Postby frost » Thu Jul 05, 2007 10:49 pm
you fix will be installing a LSD. and over fill the diff oil from one side of the axle.
Postby Stealer Of Souls » Fri Jul 06, 2007 9:40 am
I've already got an LSD.
I will suggest overfilling the diff.
Thanks.
'86 AE85.5 Levin
Stealer Of Souls
Postby NZ_AE86 » Fri Jul 13, 2007 7:24 pm
I have never had any Diff problems with mine. It's used for Track/Rally/Sprints.
Straight cut gears have less contact then a helical cut gear of the same width.
They are not always stronger either!
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Drifter4ag » Sat Jul 14, 2007 10:20 am
get a brand new crown and pinion if you love the t series so much .. normal road use wont bust the c&p unless set up wrong or less than fact1ory oil level...
over fill it ...2litres +
get a hilux ! or an f series
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby Stealer Of Souls » Mon Jul 16, 2007 4:30 pm
Drifter4ag wrote:get a brand new crown and pinion if you love the t series so much .. normal road use wont bust the c&p unless set up wrong or less than fact1ory oil level...
Okay. Because I'm a tard...
What does an F series come from? Whats the differences between an F and a T.
And it's not that I like the T that much. But it is what comes from an AE86. It has sentemental (sp??) value.
'86 AE85.5 Levin
Stealer Of Souls
Users browsing this forum: Google [Bot] and 25 guests
