Plastic plug sensor on factory air box Celica ?
Postby Charged1 » Mon Jul 16, 2007 7:07 pm
Hello I am about to install a pod and air intake pipe onto my celica but there is a plug/sensor ? stuck into the side of factory air box what do i do with this once the box is removed ? Thanks
Charged1
Postby 3T-Rona » Mon Jul 16, 2007 7:32 pm
its an intake air temp sensor.. try fit it to the intake pipe sumhow. i dare say it will make f-all difference if u just unplug it an leave it but dont quote me on it.
3T-Rona
Postby Ae92typeX » Mon Jul 16, 2007 8:05 pm
as above, many people will tap into the new pipe, however, you 'may' notice no difference if you just leave it haning
Ae92typeX
Postby soven » Mon Jul 16, 2007 8:31 pm
pull it out of the stock airbox. pull the grommet too.
Then when you get the piping for the pod filter, drill a hole then stick the rubber grommet and sensor in
soven
