Zyros wrote:Oh okay,
Well i was either thinking of Satin Black or Matt Black.
Whats your thoughts?Cans tend to fade with excessive UV too.
Is there some sort of protective coat i can use?
Voyeur wrote:For just about the same price as hiring a compressor, go and buy one, $100. from super cheap. Go to your local paint company, and ask for mistints, i got 4L of 2 pak meatallic black, for my last car for 2 dozen tui. and buy a HVLP (high volume low pressure) spray gun at the same time, i paid $85 for mine. Then you only need thinners, and hardener (if you use 2 pak) and a good filtered mask. At the end of the day if you stuff it up, it makes a good base coat.
neo wrote:Really the problem with small compressors is that they are direct drive. Once they have been going for 30mins, they get damn toasty and you end up with heaps of water in the tank, in the lines and coming out with your paint....
Hire one of them big belt drive mothers, they dont cost much for a weekend, and buy a $100 gun
