Flywheel anf P/Plate skimming
Postby TRD_ZERO » Sun Jul 22, 2007 1:18 pm
IM wanting to get my flywheel and P/Plate skimmed somewhere. Where should i go and what is the approximate cost of this?
TRD_ZERO
Postby Quint » Sun Jul 22, 2007 1:33 pm
70ish for a dual stage flywheel to be machined, If your just joe blogs.
Why do you want to get your Pressure plate machined? clutch kits are normally barely more expensive than buying a clutch by itself, so you might as well get a new P/P when your doing the clutch...
Unless of course you're not changing the clutch, but then i'd imagine it wouldn't bed again with the flywheel and P/P once its already begun to wear down.
Quint
Postby TRD_ZERO » Sun Jul 22, 2007 1:50 pm
I bought a toda flywheel with a trd p/plate and clutch plate second hand and i wanna clean them up by getting them skimmed looks like the flywheel had been sitting around for abit.
So i was doubting i could get the same clutch kit for the same price as getting it skimmed
TRD_ZERO
