Adamal wrote:Aww Bae, you jus come up to a corner, and smack it back in second gear, and bounce it off da red line and turn bro! Then you stick your arm out the window and go "CHUR BAE!!!"
ke2nv wrote: because of the power and the (lack of) weight.
gmacrae wrote:I'd imagine it will be pretty loose, should rip the tyres loose when it comes on boost in 1st and 2nd in the dry, 3rd should be ok tho. what width rear tyres can you get in a ke20?
Kender wrote:Keeping the rear springs soft will aid with traction control. Then add a rear sway bar to reduce body roll when cornering.
varix wrote:....250hp and it is useless in the wet....Hes running 205....
