SW20 Factory Airbox
SW20 Factory Airbox
Postby solitaire » Tue Jul 24, 2007 6:39 pm
Hi.
Does anyone know if there are any sensors plugged into the factory airbox on a Gen1 Turbo SW20?
When i bought the car it just had a $30 supercheap pod hanging off the afm (now K&N) ... im concerned this is not ideal... OPinions are apreciated :D
AE92, KZJ120, KDJ120
solitaire
Postby Adamal » Tue Jul 24, 2007 6:42 pm
I know the N/A's have a temp sensor, but they're MAP, not AFM, so turbo might not have that in them
Postby solitaire » Tue Jul 24, 2007 6:50 pm
Been doing some searching and the consensus seems to be that pods hanging off the afm are a fecking bad idea... which could explain why the thing runs fairly lean in comparision to other dyno plots i have seen... (af 11.5>12ish)
I did get a diagnostic error about the air temp sensor... but it has not come back since i cleared the ecu
solitaire
Postby FST4RD » Tue Jul 24, 2007 7:10 pm
I tore mine out, bloody huge pain in the bum took up more space then you could poke a stick out as well....
I replaced it with a pod (out with the factory air box and on with the pod) and it worked perfectly fine, even ran a bit better.....
Maybe just the cheap pod not letting enough air through??
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby solitaire » Tue Jul 24, 2007 8:32 pm
Hmm.... Nah its a K&N... is yours mounted straight to the afm?
solitaire
Postby Boosted_162 » Tue Jul 24, 2007 10:29 pm
http://www.trademe.co.nz/Trade-Me-Motor ... 17.htm?p=1
If your wanting to put the old airbox in :)
Postby FST4RD » Tue Jul 24, 2007 10:34 pm
yeah I had an adapter that mounted it straight to the AFM.
I made up a braket though that held it up so the AFM was in it original place so the AFM was sitting flatish, only cause I wasn't to sure lying on it's side was a good thing.
MR2SIK has it now, not to sure if he's kept the same setup but you could ask him and ask for a photo??
Edit: Just remembered Sean's got a Link setup now so unless he's got some old photo's of the engine bay you might be out of luck....
FST4RD
Postby solitaire » Tue Jul 24, 2007 10:39 pm
Boosted_162 wrote:http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Toyota/Engines-drive-trains/auction-109618317.htm?p=1
Nice just posted a question :wink:
solitaire
