Crampy wrote:I was using open throttles with aftermarket trumpets. Just put the sensor next to the inlet of the trumpets. For the vacuum lines, I just put a little filter on them.
I was going to put in a bonnet scoop at some stage as well, so it had a cold air feed rather than sucking the hot air form the engine bay. Ended up selling my BZ-G before I could be bothered though.
This was on a Blacktop, you can't do that with a Silvertop if using the stock computer, due to needing the AFM.
Caribeena wrote:yeah i had mine off for a bit! insane! whered you get the filter sox from? i found some for $200 for 4, just want to see if theres any cheeper.
Matty104 wrote:gasman,
do u reckon you could put a pic of the trumpets up without the filters on?
nz_climber wrote:Don't know how true it is, but a lot of places I have read on the internet say that filter socks over individual trumpets mess up the airflow entering the trumpet, and recommend a fully enclosed filter. As to get max flow and undisrupted flow a trumpet needs about 15-20mm between the bell end and any air filter.
BZG|Bling wrote:nz_climber wrote:Don't know how true it is, but a lot of places I have read on the internet say that filter socks over individual trumpets mess up the airflow entering the trumpet, and recommend a fully enclosed filter. As to get max flow and undisrupted flow a trumpet needs about 15-20mm between the bell end and any air filter.
The filter socks I used to use had internal springs so the end of the filter sits around 50mm from the end of the trumpet, never had any issues.
QikStarlie wrote:BZG|Bling wrote:nz_climber wrote:Don't know how true it is, but a lot of places I have read on the internet say that filter socks over individual trumpets mess up the airflow entering the trumpet, and recommend a fully enclosed filter. As to get max flow and undisrupted flow a trumpet needs about 15-20mm between the bell end and any air filter.
most of the air is drawn in from the sides not the top. thats the problem.
air box, variable trumpets and 16 vavles! is where its at![]()
