hi all, i have a question for those who have used after market cams in a 16v 4age, im wanting info about the trick of using two exhaust cams in the motor,
i have hks cam gears and will be getting some hks cams in, im getting 264 and 272 8.1mm exhaust cams so i can mix and match them round if i need later,
how is it done? is it just a straight swap in job,
do the dwells(?) on the front of the cam shaft need to be relocated in the correct side (intake side)
or should i not bother and just order intake and exhaust cams
thanks jack
