4age cams, using two exhaust cams
Postby frost » Sat Jul 28, 2007 11:41 pm
hi all, i have a question for those who have used after market cams in a 16v 4age, im wanting info about the trick of using two exhaust cams in the motor,
i have hks cam gears and will be getting some hks cams in, im getting 264 and 272 8.1mm exhaust cams so i can mix and match them round if i need later,
how is it done? is it just a straight swap in job,
do the dwells(?) on the front of the cam shaft need to be relocated in the correct side (intake side)
or should i not bother and just order intake and exhaust cams
thanks jack
Postby ChaosAD » Sun Jul 29, 2007 4:39 pm
Shouldnt have any problems. the dowels are in the same place, the cam gears just have two slots, one for intake one for exhaust
ChaosAD
Postby frost » Sun Jul 29, 2007 10:09 pm
sweet thanks for the info, i was just making sure so i wasn't left with one extra exhaust cam :oops:
Postby NZ_AE86 » Tue Jul 31, 2007 8:04 am
It just means you'll have a Dizzy drive on both cams. The position of the locating pin means nothing as you'll set the cams up with adjustable cam gears.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby toyrota mota » Wed Aug 01, 2007 6:25 pm
Sorry if this is a stupid question but why would you do this?
toyrota mota
Postby ChaosAD » Wed Aug 01, 2007 8:50 pm
say you decided you wanted to change from 264 in 254 ex to 272 in 264 ex
you could throw the intake cam on the exhaust side and will only need to buy one new cam
ChaosAD
Postby frost » Wed Aug 01, 2007 10:01 pm
ditto, and at the prices that HKS cams are at now i can afford to mix and match till i get the power band i like,
thanks for the info guys,
