Winsdscreen Wiper Motor Removal - instructions please
Postby DeeCee » Mon Jul 30, 2007 9:43 pm
Okay.. so the weekend started with a bang and ended with a fizzle for me.
18's got put on, spent 2.5 hours cleaning car after it not being clean for 9 months and then some a-hole dinged one of the front guards!! GRRRR
Then last night, whilst parking the car in the garage, the windscreen wipers fizzled out.. intermittant and non functioning.
So after checking with the BGB off celicatech, i did a test to check the functionality of the wiper motor just now and its dead.
So... how do you remove the wiper motor?
I checked my old haynes celica manual and it says unbolt and remove.
But it attaches inside the scuttle panel somewhere so how do i dis-attach the motor from the mechanism?
And if anyone has a spare wiper motor.. let me know :) 1990 Celica ST185
Dave
GT Four Adovansu
DeeCee
Postby Boosted_162 » Mon Jul 30, 2007 9:50 pm
I may just have a motor, ill check my hoard tomorrow :)
Postby DeeCee » Mon Jul 30, 2007 9:53 pm
cheers - its raining, can't drive the car and i need wipers for a warrant :lol:
i even bothered to put the interior back in just for the warrant.. murphy's law is in effect the past couple of weeks :lol:
GT Four Adovansu
DeeCee
Postby gepsk8 » Mon Jul 30, 2007 10:21 pm
can come check the car out for fee if u want. thanks
gepsk8
Postby DeeCee » Mon Jul 30, 2007 10:27 pm
Cheers for the offer, but I've already tested the motor as previously said and the wiper motor is dead. All i need to do is remove it, and i'm sure i will figure it out some way or another.
I find it more rewarding if i do my own work on the basic areas of my car.. saves me thinking about taking over the world you see :)
GT Four Adovansu
DeeCee
Postby Distrb » Mon Jul 30, 2007 10:35 pm
should just be able to unbolt it from the firewall, and pull it away slightly, exposing the hole into the scuttle panel and showing the knuckle type joint that holds the motor to the arm. just pop that off and you should be able to remove the motor
Distrb
Regular Poster
Postby DeeCee » Mon Jul 30, 2007 11:11 pm
Distrb wrote:should just be able to unbolt it from the firewall, and pull it away slightly, exposing the hole into the scuttle panel and showing the knuckle type joint that holds the motor to the arm. just pop that off and you should be able to remove the motor
cheers :)
i'll have a play tomorrow night
GT Four Adovansu
DeeCee
Postby matt dunn » Tue Jul 31, 2007 1:11 am
Sometimes it depends on the particular location and design of the wiper arms and location,
but if you remove the bolts that hold the motor to the firewall and then move the wipers up the screen by hand it will allow the wiper linkage to come out the hole so you can pop the linkage off the motor.
Hints for working on wipers,
Always work with them unplugged if you are getting into the motor arm part. They just about have enough grunt to chop off a finger,
and dont remove the arm fron the center of the wiper motor, ( usaully a 10mm head bolt or similar) unless you want to spend the next 3 weeks trying to get it to park in the right place.
Postby strx7 » Tue Jul 31, 2007 7:50 am
matt dunn wrote:and dont remove the arm fron the center of the wiper motor, ( usaully a 10mm head bolt or similar) unless you want to spend the next 3 weeks trying to get it to park in the right place.
depends on the linkage joints, some vehicles if you pop the plastic joint it's lifespan after being put back together is severly limited because they are designed to be put together at the factory and never removed
Postby DeeCee » Tue Jul 31, 2007 9:46 am
DOH!!!!!!!
removed the arm to get the scuttle panel off.. will try moving the linkage by hand and seeing if the motor detaches easier
GT Four Adovansu
DeeCee
Postby Bling » Tue Jul 31, 2007 11:17 am
Don't worry, i've removed the same thing and as Matt says, just takes a bit sometimes to get it back on correct. Not knowing this at the time my wipers ended up going off my screen and scratching a bit of paint (only a KP60 tho :P) you'll work it out :lol:
Postby matt dunn » Wed Aug 01, 2007 12:15 am
Putting the arm on/off the linkage at the bottom of the screen adjusts the span of the wiper and can get it off the screen,
Changing the location of the arm onto the shaft of the motor will never let them get off the screen, just change where they stop,
so they will still sweep properly, but may stop mid sweep etc etc.
If you got them off the screen you changed a different part to what I mean.
Postby Boosted_162 » Wed Aug 01, 2007 7:23 pm
If you have the motor disconnected, and put it on slow speed (constant on, not intermitant) does the arm go round one way constantly? Im just checking if my spare motor does actually work properly.
Postby matt dunn » Wed Aug 01, 2007 7:52 pm
Boosted_162 wrote:If you have the motor disconnected, and put it on slow speed (constant on, not intermitant) does the arm go round one way constantly? Im just checking if my spare motor does actually work properly.
Yes the motor always just spins one direction, and so the arm will always do full circles and just keep going till you turn it off.
Postby Boosted_162 » Wed Aug 01, 2007 9:02 pm
Awesome, it works fine then.
Cheers Matt.
Postby DeeCee » Wed Aug 01, 2007 9:06 pm
Thanks Matt :D
GT Four Adovansu
DeeCee
