Dynoed my caldina now with plots
Postby 99gtt » Fri Aug 03, 2007 3:35 pm
I am about to rebuild my engine so i thought i better get a dyno run with the factory ecu, to compare later as i will be getting an aftermarket ecu. I got 309 hp at the hubs. [img][img]http://i101.photobucket.com/albums/m45/99gtt/CCI00009.jpg[/img] Image[/img]
SOON TO BE 500 HP
99gtt
Postby gleem » Fri Aug 03, 2007 3:42 pm
haven't seen you round here in a while james, the big bore is still sweet :D
gleem
Postby DeeCee » Fri Aug 03, 2007 4:23 pm
www.flickr.com or www.photobucket.com
create an account and you're good to go
GT Four Adovansu
DeeCee
Postby flygt4 » Fri Aug 03, 2007 5:01 pm
that equates to 227kw, not bad. running what turbo? how does it calculate flywheel figures? that parts always had me slightly confused
flygt4
Postby fivebob » Fri Aug 03, 2007 5:02 pm
283HP at the hubs, not bad for 7.5psi ;)
Postby pureadrenalin » Fri Aug 03, 2007 5:05 pm
I'm wondering what turbo too.
If it takes you till 5k rpm to hit 7psi.........
Nice power figure for 7.4psi !!!
pureadrenalin
Postby flygt4 » Fri Aug 03, 2007 5:08 pm
all the dyno operators need to work out a standard, as some give out flywheel calculations and some give real at the wheels figures :?
flygt4
Postby Santa'sBoostinSleigh » Fri Aug 03, 2007 5:14 pm
99gtt wrote:I got 309 hp at the hubs.
the dyno plot says at the flywheel?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby fivebob » Fri Aug 03, 2007 5:15 pm
flygt4 wrote:all the dyno operators need to work out a standard, as some give out flywheel calculations and some give real at the wheels figures :?
That's why it pays to know how to read the various dyno manufacturers plots. Which is why I divided by the TCF (or should that be BSF) of 1.09 to get the actual figure at the hubs. The incorrect ratio of 4.160 (should be 4.165) also makes a very minor difference, but it's only about 0.25hp in this case.
Postby 99gtt » Fri Aug 03, 2007 5:30 pm
pureadrenalin wrote:I'm wondering what turbo too.
Same turbo as bazda
SOON TO BE 500 HP
99gtt
Postby flygt4 » Fri Aug 03, 2007 6:23 pm
who measures in PS and lb/ft anyway :wink: it should be against the law to work in old money :lol: we should be strictly kw and nm (227kw/371nm flywheel)
get a decent bottom end and ecu on it and stretch the turbos legs a bit.
flygt4
Postby Mr Revhead » Fri Aug 03, 2007 6:23 pm
hp ftw!!
we speak english.... not french
Postby flygt4 » Fri Aug 03, 2007 6:24 pm
Mr Revhead wrote:hp ftw!!
quiet old man :lol:
flygt4
Postby IH8TEC » Fri Aug 03, 2007 6:51 pm
dyno figures don't mean crap, numbers on the track is where its at :lol:
my new philosophy anyway :)
Postby Lith » Fri Aug 03, 2007 7:00 pm
Mr Revhead wrote:we speak english.... not french
ps = German :)
So what is that correction factor mean? Still pretty decent power for 7.4psi, though don't really know exactly how to relate that figure to anything.
Yikes that turbo is laggy!!!!
Lith
Postby Mr Revhead » Fri Aug 03, 2007 7:59 pm
hp = english!
Postby strx7 » Fri Aug 03, 2007 8:08 pm
your engine has std cams aye, peaky torque curve
Postby JT » Fri Aug 03, 2007 8:24 pm
Lith wrote:So what is that correction factor mean? Still pretty decent power for 7.4psi, though don't really know exactly how to relate that figure to anything.
from fivebob's post a few above yours..
fivebob wrote:That's why it pays to know how to read the various dyno manufacturers plots. Which is why I divided by the TCF (or should that be BSF) of 1.09 to get the actual figure at the hubs.
However, if it is truely PS then remember to multiply by 0.9863 to convert to hp in which case it's 279.9 :wink:
edit: Wasn't this the car we had the big estimation thread about how much power it was really going to make?
Not that it makes any difference to the performance of the car.
<goes back to error propagation calc's with partial differentiation for surveying observations :roll: >
JT
Postby Quirky » Fri Aug 03, 2007 9:48 pm
For most cars, or is 4wd? Roughly, you times the horsepower at the wheels by 1.2-1.3 to get the power at the flywheel, read it somewhere, dont know where there...
Hello There
Quirky
Postby Lith » Fri Aug 03, 2007 10:05 pm
JT wrote:from fivebob's post a few above yours..
Sorry I meant correction method, I know what correction factor is but am used to seeing SAE or DIN used. What is the one used here?
Quirky wrote:For most cars, or is 4wd? Roughly, you times the horsepower at the wheels by 1.2-1.3 to get the power at the flywheel, read it somewhere, dont know where there...
You should actually be dividing by 1 - drivetrain%.... so if its 20%, it should be 227kw / (1 - 0.20) or 227/.8
Lith
