missing ECU plug, smallport
Postby rollaholic » Sun Aug 05, 2007 2:09 pm
alright, so the smallport loom i have for my smallport conversion is missing one of the plugs - the 12 pin plug, which is supposed to have the following connections.
1 EFI Main
2 BATT
3 Exhaust Temp Sensor
4 Curcuit Opening relay(fuel)
5 Stop Lamp Switch
6 A/C Amplifier
7 EFI Main
8 Check Engine Lamp
9 Exhaust Temp Warn. Lamp
10 Air Conditioner clutch
11 Speed Sensor (instrument panel)
12 Idle Up Diode
seems like some of these are going to be fairly important to the running of the engine ;) does this plug connect to parts of the car other than the engine? because i got a complete smallport engine, it doesnt look like anythings been hacked off the loom on the internal side so i figure the missing plug stayed with the vehicle. can anyone suggest a solution?
Been there....
Postby jondee86 » Sun Aug 05, 2007 7:11 pm
Yeah.... dashboard/body loom, which is completely separate from the
engine loom. I had to buy a complete body loom to get that missing
plug.... still, I have heaps of spare coloured wires now :)
Cheers...
Watch this space >>> <<<
jondee86
Postby KinLoud » Mon Aug 06, 2007 10:38 pm
Yeah - often people forget the body loom plug that connects to the computer.....
My guess - try a 4afe loom of the same year. They will both be map sensor so there is a good chance that they will have the same connections. Good luck.
Ken
Ham
021 408 863
Postby QikStarlie » Mon Aug 06, 2007 11:23 pm
common plug, pretty sure starlets and cynos's and the like around the same year use the same plugs, so other toyota are sure to as well. pick a part one
QikStarlie
Postby rollaholic » Mon Aug 06, 2007 11:51 pm
thanks for the replies guys. jondee what did you do about the other internal plugs from the engine loom? splice them into your existing bluetop loom?
Knit yourself a loom this winter :)
Postby jondee86 » Tue Aug 07, 2007 9:59 pm
When I put the smallport in my AE86, I modded the smallport loom...
and what a farkin mission that was :!: :!: :!: Had to unravel it, identify
every single wire, extend all the wires that went to the main ECU plugs
and splice in a few extras to match up to the AE86 dashboard loom.
Scored a spare body loom plug and spliced that into the engine loom in
the same place at it sat on the AE86 loom... to make it all look factory :)
From memory, the only thing I took from the AE86 loom were the plugs
and wires for the wiper motor and screen washer.
Pic shows what it looked like during the trial fit... I've tidied it up since
then. http://homepages.ihug.co.nz/~wjd/loom01.jpg
Took a lot of hours, spread over a lot of months to get it done... lucky I
didn't need the car as a daily driver. Everything works just as it should,
except when you bridge a couple of pins in the diagnostic plug the starter
kicks over :oops: I explain that as the remote starter connection :)
Cheers... jondee86
jondee86
Postby matt dunn » Tue Aug 07, 2007 11:33 pm
The one I did i had to lengthen the smallport loom to get the ecu to sit in the correct place.
Postby Santa'sBoostinSleigh » Thu Aug 09, 2007 2:21 pm
i may have the plug youre looking for attached to part of my loom if need be?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby rollaholic » Thu Aug 09, 2007 6:24 pm
hey santa,
im keen as a bean. also on the internal side of the loom theres three other plugs - ones massive, and two are smaller... i'd be pretty keen to get whatever these are plugged into as well. maybe the whole dash loom? whatever works for you i guess, let me know price etc!
Postby Santa'sBoostinSleigh » Fri Aug 10, 2007 2:36 pm
well my smallport AE92 loom is merged with my blacktop AE111 loom
so not sure what plugs are there and what are being used on my racecar
will try get some time to get photos of the spare plugs during the weekend
Santa's Mega Sale
Postby rollaholic » Fri Aug 10, 2007 6:52 pm
where do the wires on that third plug actually attach to the car anyway?
Postby Grotty » Fri Aug 10, 2007 8:18 pm
if you send us the ecu we can wire in your power wires into the ecu,
Import Enhancements Ltd
Wellington.
Grotty
Postby fx gt » Fri Aug 10, 2007 8:29 pm
Grotty wrote:if you send us the ecu we can wire in your power wires into the ecu,
Wellington.
what do you mean by power wires? :P
yer im feeling noobish.
fx gt
Postby rollaholic » Fri Aug 10, 2007 11:47 pm
i did consider sending my loom etc to you guys, but i want to learn about this kind of thing - if i cant work out the loom and ECU on a 25 y/o car im not going to have much luck with newer stuff am i ;)
