4age starting issue
4age starting issue
Postby rwd_mayhem » Sun Aug 05, 2007 6:55 pm
OK Ive done a search but didn't answer my question,
this morning i took my car to panel beaters, had to disconnect battery for welding, then when i was leaving it wouldn't start, just ticks when the key is turned. so put jump start pack on it and it started straight away.
drove home thinking i just had a flat battery and the drive home would charge the battery (which is relatively new) back up to normal, but no! it did the same thing. jump started it and it was sweet.
so i checked the connections/terminals, they seem all good, tight as and not corroded.
is my alternator naffed? its weird though because Ive had no issues starting or charging recently.
current: 1975 Valiant Regel
rwd_mayhem
Postby gepsk8 » Sun Aug 05, 2007 7:02 pm
u checked for current draw?
does it click? or machine gun?
where battery from? Get a auto sparky to charge it and check it.
gepsk8
Postby l1ttle_d3vil » Sun Aug 05, 2007 8:00 pm
start the car up and check what voltage is on your battery. if its charging it should be somewhere in the region of 13v or more.
Postby rwd_mayhem » Sun Aug 05, 2007 8:04 pm
gepsk8 wrote:u checked for current draw?
havn't checked for current draw.
clicks like a machine gun.
battery is a century 11 plate.
we have one of those battery testers at work so will have to do that.
l1ttle_d3vil wrote:start the car up and check what voltage is on your battery. if its charging it should be somewhere in the region of 13v or more.
Cheers, will do that too.
rwd_mayhem
Postby Dell'Orto » Sun Aug 05, 2007 8:05 pm
Terminal probably isnt tight enough, or is a bit grubby. Rapid clicking usually means its getting reasonable voltage.
Postby rwd_mayhem » Sun Aug 05, 2007 8:16 pm
Mmm, Boost wrote:Terminal probably isnt tight enough, or is a bit grubby. Rapid clicking usually means its getting reasonable voltage.
but i double checked them, both tight as, i gave the positive a clean up. the ground was looking a bit old though, getting a little bit rusty but i didnt touch it i only disconnected the positive, only touched the positive, left the negetive how it had been for ages. hopefully that is the problem, nice easy fix. Thank you.
rwd_mayhem
Postby gepsk8 » Sun Aug 05, 2007 8:45 pm
k, with machine guning sounds like ur battery is flat.
reasons why?
check its charging correctly, 14-14.4 on toyota's normally,
current draw should be 0.05amp with everything off,
Troublesom century batteries $&#$% out or not charge when u brought it.
gepsk8
Postby rwd_mayhem » Sun Aug 05, 2007 9:26 pm
gepsk8 wrote:k, with machine guning sounds like ur battery is flat.
reasons why?
ok 2 different opposing opinions about the clicking sound.
how do i check current draw?
rwd_mayhem
Postby gepsk8 » Sun Aug 05, 2007 11:53 pm
on digital multi meter 10amp circuit
gepsk8
Postby scope » Mon Aug 06, 2007 1:41 pm
liam the 36 used to be a machine gun when the battery was flat, would require a charge when it did that
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby rwd_mayhem » Wed Aug 08, 2007 8:00 pm
yip my batterys gone, got it under 2 years ago so shud be replaced for free.
rwd_mayhem
