Caldina GTT battery for stereo
Postby magnazan » Fri Aug 10, 2007 2:27 pm
I'm running 2 amps (Forget what output but not massive amounts) 2x 100w/rms soundstreams, 2 x 60w/rms sonys and a 12inch alpine sub. All from a Alpine head (standard 1 slot). My question though is the Caldina battery grunty enough to power all this plus all the other electronics in the car (Lights, wipers, alarm etc)?
Or are people running secondary batteries?
magnazan
Postby DeeCee » Fri Aug 10, 2007 2:36 pm
what is your current battery in the caldina?
for the easy upgrade, get a bosch gold - or something with around 450+ CCA or so.
anything sitting around the 300 - 350CCA mark is not ideal for audio setups unless you only use your system when you drive and not parked up.
As for dual battery systems, only necessary if you intend on wanting to play for 3-4 hours at a time when the car is off
GT Four Adovansu
DeeCee
Postby magnazan » Fri Aug 10, 2007 2:54 pm
Think the battery is around the 370cca mark and yes i only use it when driving. I'd probably just carry a spare battery if i was going to run it for a few hours.
magnazan
Postby DeeCee » Fri Aug 10, 2007 3:14 pm
instead of carrying a spare, just upgrade the battery to something larger that can handle the jandel.. save having to change over as well :)
GT Four Adovansu
DeeCee
Postby Boosted_162 » Fri Aug 10, 2007 5:36 pm
Or get one of those portable battery jumpers? I have one, and its so bloody handy.
Postby Emperor » Sun Aug 12, 2007 6:08 pm
Boosted_162 wrote:Or get one of those portable battery jumpers? I have one, and its so bloody handy.
Agreed!
Does anyone know at what voltage cars will not start? Cause I always get worried about leaving my Skyline's music on with the engine off. My volt gauge usually sits on 12.2 for about 30 mins with the sub cranking before dropping to 12.1 and lower.
But starts at 11.5, but scared to go any lower.
Emperor
Postby Alex B » Sun Aug 12, 2007 6:16 pm
NS70 is a good size battery if it will fit.
Postby spark_38 » Mon Aug 13, 2007 9:42 pm
pyro_sniper2002 wrote:NS70 is a good size battery if it will fit.
Ditto. Had one in my old GT-4, 520CCA 13 plate from memory. Never had any issues with it. I ran two amps a smaller 60Wx2 for the fronts and a 350W monoblock for the sub.
spark_38
