Possible engine conversions for a KP61 '83 RWD Starlet
Postby starlet drifter » Sun Jul 28, 2002 9:16 pm
Although I love ringing the *&^% out of the trusty 4K, I think I 'm in need of a bit more power... I was thinking of either a RWD 4AGE, 2T or a 12A rotor!!! Any opinons or help with the final decision would be awesome!!! What I'm basically after is a lot of power (naturally!!), with if possible the least amount of work/modifications needed (I'm aware there will be work needed, mounts, fuel, brakes etc etc), but I really can't avoid that ay?! And I really dnt want to go with forced induction either (insurance pple suck). Or, could anyone give me any ideas on how to supe up the 1300??? I've already got extractors, 2 1/2"free-flow exhaust (got a really nice rumble to it!! :D ) and a K&N filter... anyone??
Thanks heaps for any help people!! :D
mmm 4age kp starlet :D
starlet drifter
Postby feedah » Sun Jul 28, 2002 9:21 pm
If it were me I would slap a 4age with t50 g/box into the sucker. Then do up the brakes and suspension & maybe a stronger diff. It has been done heaps of times which means you can learn from others mistakes and tap them for ideas.
My 2c
Dave
feedah
Postby Mr XXX » Sun Jul 28, 2002 9:42 pm
Talk to GROTTY, he'll tell ya what he thinks, he has a few Starlets...
Mr XXX
Seedy Al's Chop Shop
Current Rides - 7-age At141 Corona, 81 kE70 Sedan, 1970 MS55 Crown, 72 B1600, ke25 Corolla x 2, Suzuki Carry Van x2, 910 BLuebird, 4age KP starlet
My Life Is a F*cken Project
Suck a Dx Chris
Mr XXX
Postby Stu- » Mon Jul 29, 2002 12:03 am
Um, 4age Turbo? We've done a whole heap of these conversions into rwd starlets. 4age or 4agze, T50 Box, Hilux Diff. Ledge setup. If you want a 4age Turbo manifold yell out as we make these aswell.
Project Thread
Stu-
Postby suberimakuri » Mon Jul 29, 2002 2:46 pm
Most engine you'll be able to get NA power out of is of course a rotary.
That said, 160-170hp out of a 4AGE NA (with std ecu), would be plenty fast in a starlet.
120hp in my KE35 with 2TGEU is plenty for drift, and i have standard springs, good shocks and bushes though.
So...... I would recommend bluetop 4AGE, with perhaps a turbo conversion by EP71-4age later on for more power.
2TG is a pretty tight fit in a starlet... not to mention a bit heavy for it. (20kg over 4AGE)
suberimakuri
Postby Stu- » Mon Jul 29, 2002 11:10 pm
The ol' trusty blue top is hard to beat. Even in N/A form with the tvis ripped out (TVIS is for pussies! :D ) they go damn well. Guaranteed to blow starlet diffs
Project Thread
Stu-
Postby Nuty|Mike » Tue Jul 30, 2002 10:20 am
Lexus V8 ???????? 8O
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby starlet drifter » Tue Jul 30, 2002 4:47 pm
Thanx for the help people, looks like i'm going with the 1600 blue top, but with carbies or with the injection still??? Sorry, just one more question!!
starlet drifter
Postby ezy10s » Tue Jul 30, 2002 5:09 pm
starlet drifter wrote:Thanx for the help people, looks like i'm going with the 1600 blue top, but with carbies or with the injection still??? Sorry, just one more question!!
while the carbies do produce more power(apparently) unless you know wat your doing with them they are a bastard to tune well. at least with the injection setup you will have a car you can hack(still plenty of skid potential) and drive everey day (smooth too). and if you havnt done an efi transplant before dont worry there are plenty of us who have and will be glad to help.
Member #244
Gone fishing until further notice
ezy10s
kp engines
Postby Grotty » Tue Jul 30, 2002 6:45 pm
I'd say go 4AGE blue top with injection, cos the carbs are a bitch, but do give about 8-10hp extra over standard. but drive like a bitch and fully suck the gas.
apart from the 4age which is the Easiest to do imo. the rotor is always a good upgrade. but will need some fire wall cutting and opening up.
a worked 13b/12a will go harder than a 4agte (turbo on standard bluetop) but the 4agte will be way cheaper in the long run. !!
Ezy10s is a massvie source of info for the 4age !! hint hint
laters
hayden
Grotty
Postby starlet drifter » Thu Aug 01, 2002 11:45 pm
Swee, thanks for the help guys, looks like i'll b going with the 4AGE and a t50 'box! damn i cant wait!! All i need now is $$$$ (by the way, how much am i looking at, in terms of spending...?)
POCKET ROCKET!!!! damn straight be-arch!!!
Cheers :lol:
starlet drifter
Postby ezy10s » Fri Aug 02, 2002 10:26 am
[quote="starlet drifter"]Swee, thanks for the help guys, looks like i'll b going with the 4AGE and a t50 'box! damn i cant wait!! All i need now is $$$$ (by the way, how much am i looking at, in terms of spending...?)
the engines are easy to get as there are so many fwd ones around, the hard part is the t-50 with 4age bellhousing.... and the rwd ancillaries although you can boogy up the fwd bits to suit(just depends how fussy you are really)
approxiamately $1000 would see it together assuming you did the install yourself
Member #244
ezy10s
Postby simonlenihan » Mon Mar 15, 2004 11:03 am
Anyone wanna make a list of all the parts needed to get a 4age running rwd in an auto kp61 starlet? :)
got a mate that just baught one, wanna do the conversion and dont kno alot about toyotas :P
simonlenihan
Postby Volatile » Tue Jun 15, 2004 11:39 am
sorry to bring this post of from the dead, but i've heard when you go for injected 4age in a starlet you need to move the brake booster?
how is this done?
Volatile
Postby Rob » Wed Jun 16, 2004 8:00 am
I've got a high compression 3k head with a 3 angle valve grind that will add a a couple of hooves to the 4k.
Just have to find it
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby KE10 door slammer » Sat Jun 19, 2004 3:56 pm
Nuty|Mike wrote:Lexus V8 ???????? 8O
i was going to say that, the 1UZ would fit in ok, just need to move the firewall back, better than some sacky old 4AGE
KE10 door slammer
booster lies
Postby ezy10s » Sat Jun 19, 2004 7:07 pm
[quote="Volatile"]sorry to bring this post of from the dead, but i've heard when you go for injected 4age in a starlet you need to move the brake booster?
Flat out lies you have been told. plenty o room for injection and booster etc
Member #244
ezy10s
Postby starlet drifter » Sat Jun 19, 2004 7:15 pm
holy, i orginally posted this topic 2 years ago, and its still going... awesome. (man i sound like an idiot thou :oops: )
well, i hav got everything i need, bluetop 16v, modded waterpump, R30 skyline fuel pump, K50 'box, custom alternator mount, throttle body swapped to other end of plenum and some ae86 extractors. Apart from the clutch which is coming next week, then i just hav to run a new bigger fuel line and wire it up.
see you
starlet drifter
