method wrote:I always bridge it at the ECU.
You just need to earth T.
(E1 stands for earth)
that sounds good. is the ECU under the stereo area?
IH8TEC wrote:you say you put a pipe to a cold air box, what kind of pipe is it? possibly it's just collapsing, unless it's a metal pipe?
evil_si wrote:how did u earth the battery? did u run a cable from the battery to the engine?
or did you earth the battery were it sits in the boot to the chassis, and earth the engine to the chassis?
themaleman wrote:check ya line coming from the intake to the map sensor, should b on the right of ya intake
pyro_sniper2002 wrote:If you have a good earth to chassie and a good earth for chassie to engine thenn you shouldnt need to. And try check the codes again, just make sure you have the paper clip in there goodly. Dont remove the gunk thats in there. It stops the plug from rusting up
