DeeCee wrote:Wondering if a st205 ct20b can be fitted to a beams 3sge in an altezza.
I have a manifold and ct20b turbo from a st205 and the ct20b needs a rebuild and i'm looking at a new car for myself anyway.
1. would the manifold bolt up or would something have to be made up for the application.
2. potential of a ct20b on a beams?
3. i assume aftermarket ecu.. suggestions?
Dave
Distrb wrote:DeeCee wrote:Wondering if a st205 ct20b can be fitted to a beams 3sge in an altezza.
Dave
2 - could be alright. beams 3sge head flows very well up high in the rev range, so the ct20b in stock form could choke it a bit.
\sergei wrote:DeeCee wrote:yep - will look at doing a thicker gasket to reduce compression
Thicker headgaskets do not reduce detonation.
sergei wrote:On stock beams? CT20b would be big enough. I think it actually will be too big.
strx7 wrote:go the honda route, larger turbo, running less boost. higher compression will spool a larger turbo faster, and means more HP for the same PSI, or less boost for same HP than a lower compression engine.
DeeCee wrote: or i just buy woolly's car..
DeeCee wrote:so you think viable? or maybe just go to a td03/04?
