try_hard wrote:thanks for the help guys. yes i was thinking the t67 mite of been abit of overkill so maby the t3/t4 is a better idea. but yes am planning to get the head done once the block is compleated. was thinking for cams the 264 duration with the 8.1 lift over the 272, 8.1 life. i havent put a price cap on the project as i want it to be top quality, and worth the $ and time that gose into these things. 10's would be nice.
i'm lead to believe the fastest 4age run 9's. is this rite.
its going into a ae92 trueno at the moment but are having other thoughts at the moment or maby a old skool rolla.
tsoob wrote: i started with open cheque book and now its almost got no cheques left......
try_hard wrote:
i have done abit of research. i understand it is going to be expensive, but its a toyota and in my eyes its worth it.
Mr Revhead wrote:TRD rods are 19mm
as mentioned aboce, the cranks are the same
may i suggest some research, theres a tonne of info out there and it appears your not overly familier with the 4age.
500hp will cost you a lot. well done if you can do it for under... oh say $20k
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
levinguy wrote:why not copy bazda's 7agte setup and play with the head - proven power and reliability already, and room for more power with cams
its boring, but its been done before
