evo injectors on a microtech,
Postby tsoob » Thu Aug 16, 2007 11:40 pm
i was told from a mechanic that with my microtech ecu i will need to run resistors is that right? because they are a low resistance injector ??
tsoob
Re: evo injectors on a microtech,
Postby matt dunn » Fri Aug 17, 2007 12:23 am
tsoob wrote:i was told from a mechanic that with my microtech ecu i will need to run resistors is that right? because they are a low resistance injector ??
Just finished doing a full EVO ECU and Loom so I can say that the EVO's run injector resistors from factory, so that means they are low resistance for sure, so yes you will, as I dont think microtech's have current control like motec's.
Matt
Postby tsoob » Fri Aug 17, 2007 7:26 pm
thats great thanks matt.
tsoob
Postby tsoob » Mon Aug 20, 2007 11:48 pm
hey matt i read in the install manual that the ecu should not be run off the starter (ie main fuse that is fed from starter) ? have you ever had any problems doing so? we have installed a mother of a positive feed in to the starter then reasonable feed to the main fuse box??
tsoob
Postby matt dunn » Tue Aug 21, 2007 12:39 am
Have not done a microtech myself, mainly link's and motec.
I have had problems where the link's had troube starting if the ECU power is fed direct from the key along with too many other accessories, and the starter is too,
but if one of them run's a relay it's fine.
As longf as you have a large enough cable and not too many connection along the way you'll be fine.
Mostly seen the voltage drop problem where an ecu was wired in on top of a std loom and just hooked into a random ign feed.
Postby strx7 » Tue Aug 21, 2007 7:52 am
matt dunn wrote:I have had problems where the link's had troube starting if the ECU power is fed direct from the key along with too many other accessories, and the starter is too,
i've seen that too on a v8 hilux conversion
Postby tsoob » Tue Aug 21, 2007 6:01 pm
ok, i have installed a muther of a feed wire (suitable for marine use) and will be run on its own fuse etc so sound like its ok.
tsoob
Postby gepsk8 » Tue Aug 21, 2007 6:59 pm
little of subject, do 4agze injectors need resistor?
gepsk8
Postby IH8TEC » Tue Aug 21, 2007 7:01 pm
gepsk8 wrote:little of subject, do 4agze injectors need resistor?
yes
Postby tsoob » Mon Oct 08, 2007 2:26 am
well i think the resistors are part of the problem, should they be on the positive 12v in or do they go on the neg feed from ecu? we have been in the garage all bloody weekend and it just wont start, can any one help?
tsoob
Postby RedMist » Mon Oct 08, 2007 7:15 am
Links, and I suspect a majority of aftermarket ECU's, require a clean power source. If the voltage drops too much the ECU will reset with a resulting stop in all ECU functions momentarily. I suspect that Links wont even power up until the resulting power drain is removed, IE you stop the starter motor.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby tsoob » Mon Oct 08, 2007 10:25 am
voltage is 12 volts and over 13 when i hook up the falcon to the battery with jumper leads, so dont think its voltage drop problem, it turns over well, can smell heaps of fuel around and has got plenty of spark??
tsoob
Postby strx7 » Mon Oct 08, 2007 2:51 pm
are you taking that reading from where the ecu has its 12V + source from?
Postby tsoob » Mon Oct 08, 2007 5:22 pm
no from the hand controller, i was talking to my mechanic today and he thinks i have the cas wrong, i did not know there is a dot that must be lined up to make it run so will go out to the shed now and try it.
tsoob
Postby tsoob » Mon Oct 08, 2007 9:56 pm
still wont go ive had enuf, who can tune a microtech in auckland? - and knows what they are doing?
tsoob
