larryex wrote:. Yes it has new plugs etc and yes the timing is spot on blah blah so I am starting to look toward the ECU, the injectors themselves, or the fuel pressure reg, which seems to be working ok. It seems ok at idle but the minute you lift it just above idle it bags out very badly and starts pouring black smoke out. I have run out of ideas, is there someone who can offer good advice on this one?? Cheers, Chris
strx7 wrote:you need to work out WHY the check engine light comes on.
if you dont know how to diagnose it yourself, you're best to take it to an auto sparky otherwise you just waste your time and money replacing bits which have nothing wrong with them. Surely you could get it to spit an error code of some description.
larryex wrote:strx7 wrote:you need to work out WHY the check engine light comes on.
Yes thats right, I am trying to work that one out. If I knew how to diagnose it myself, i would not be asking on here would I??? And no, it wont spit out any codes even when bridging TE1 and E1 at the ecu. Not wasting any time and money either, just seeking advice. I am an A grade mechanic with 15 years exp thats why its even more frustrating, although very little toyota knowledge hence asking here.
