toymachine wrote:Design?
As far as paint/primer goes, i've found the layer on my Trueno to be *pathetically* thin, slight scratch or knock and i'm seeing metal.
Adamal wrote:Fish oil mate. They started dunking their stuff in fish oil.
~SlideWays~ wrote:As a comparison, my '87 GTZ has surface rust in the roof at the top of the windscreen, rust in the rear parcel tray near one of the clip holes which must have spread and rust under the rear number plate where the two 'hooks' go through. I've rust killed the lot and plan to remove both front and rear windows to check its ok...ah the joys of having a panel beater as a neighbour
And the comparison is an '89 GTZ I went to look at with one of the members here (not naming incase its some uber secret project now ). But I looked all over it with a torch under the parcel tray even and there was NOTHING!!
Gah...the b**tard
toymachine wrote:~SlideWays~ wrote:As a comparison, my '87 GTZ has surface rust in the roof at the top of the windscreen, rust in the rear parcel tray near one of the clip holes which must have spread and rust under the rear number plate where the two 'hooks' go through. I've rust killed the lot and plan to remove both front and rear windows to check its ok...ah the joys of having a panel beater as a neighbour
Gah...the b**tard
Hah, mines rusted in the exact same places.
