EFI 2TGEU Help
EFI 2TGEU Help
Postby ke25sr » Sun Sep 02, 2007 10:01 pm
Ive just converted my 2tg to EFI.
And I've had some small issues. Like it wont go...
as far as i can see I've wired it correctly and i no The ECU is in good order.
So I've missed something.
Has any one wired one of these up before? Do you have any advice?
ke25sr
Postby rollaholic » Sun Sep 02, 2007 11:08 pm
whats it missing? fuel or spark?
Postby ke25sr » Sun Sep 02, 2007 11:14 pm
It has Spark and good fuel pressure.
Its got power at the ECU and the earths are good.
I think ive missed a wire some were but cant see it on any diagrams.
ke25sr
Postby matt dunn » Mon Sep 03, 2007 12:25 am
From memory the ECU is fuel only.
I wired one from scratch in a starlet a while ago,
was a basturd of a job.
Make sure you have the trigger wire from coil -ve to the ECU.
Postby slonlo » Mon Sep 03, 2007 9:48 am
when you say wont go, does it do anything
just crank over or does it splutter
'89 LiteACE van
slonlo
Postby ke25sr » Mon Sep 03, 2007 10:45 am
slonlo wrote:when you say wont go, does it do anything
It just cranks. not even a small attempt.
ke25sr
Postby slonlo » Mon Sep 03, 2007 11:32 am
it should splutter/ half run on the cold start injector at least
id check for voltage at the ecu while cranking
somethings (radio ect) turns off while cranking so where did you tap the power from
'89 LiteACE van
slonlo
Postby ke25sr » Mon Sep 03, 2007 8:11 pm
ok i got it to start but it wont stay running.
if i turn in the reds on i hear a click in the tps or air flow sensor ( im not 100% on which one) then i turn ke ind VROOM it will start. runs for a few second then dies.
if i try to start it again it wont fire.
Leave it for 5 minutes and it will do the process again.
ke25sr
Postby Alex B » Mon Sep 03, 2007 8:16 pm
ke25sr wrote:if i turn in the reds on i hear a click in the tps or air flow sensor ( im not 100% on which one) then i turn ke ind VROOM it will start. runs for a few second then dies.
Anglais?
Postby ke25sr » Mon Sep 03, 2007 10:03 pm
Ok the ticking was the cold start injector opening.
I was missing a power to the injector resistor.
anyway it now runs and very well. I had to trick the air flow sensor as it was a little rich.
Thank you for all your help.
I'm extremely stoked i managed to wire up my own EFI even if it is a 2TGEU Dinosaur system.
ke25sr
