Hi, I want to know if it's possible to put front coilovers (tein) out of an altezza into a ke20?
I know modification is required, but I don't know exactly what or if it is possible/legal?
Info would be appreciated, thankyou
kharmis wrote:but I don't know exactly what or if it is possible/legal
kharmis wrote:Still learning on the suspension side, had 2 suggestions though, one was to machine up an alloy mount for the bottom?
Other was to grind the teins flat, modify the original ke20 strut housing and fit the shocks inside?
Mmm, Boost wrote:kharmis wrote:Still learning on the suspension side, had 2 suggestions though, one was to machine up an alloy mount for the bottom?
The latter suggestion would likely destroy the shock from heat, the former would work if you could somehow figure a way to make it sit solidly.
