Can anyone detail the symptoms of a blown regulator in a 4K DX?
Basically, the car will run by itself, but seemingly not charge the battery. There is 11.08 volts with the car off, but this isn't even enough to give dash lights let alone start the car. I'm reading 13.5v off the alternator without the battery connected, and about 1v under that with it connected. I figured the battery was poked, so the owner has tried one out of another car which was working fine, but after a couple of starts, it is now "flat" too.
With jumper cables connected off another car, it will start no worries. The starter motor doesn't appear to sound strained when starting, and it push starts fine.
Ideas?
