TRD_ZERO wrote:How often to you plan on adjusting the coilovers? I had to have a set as i though it would be cool to adjust it up and down changing the height and all. YOu get over it, basically to set it once to the desired height and thats it. so cheaper option would be to get the damper adjustable with lowered springs. My 2c
Scotty wrote:TRD_ZERO wrote:How often to you plan on adjusting the coilovers? I had to have a set as i though it would be cool to adjust it up and down changing the height and all. YOu get over it, basically to set it once to the desired height and thats it. so cheaper option would be to get the damper adjustable with lowered springs. My 2c
Well every time you adjust them if its a road car you would have to get them recertified
TRD_ZERO wrote:NO they dont, do a search on the forum and it will explain everything.
