When they say don't work under a car on a jack...
Postby RunningRich » Sun Sep 30, 2007 4:04 pm
they mean it!
Note the round dent adjacent to the drain bolt? That is from the wheel of a small hydraulic jack that tipped as the jack was being lowered. The car's rear wheels skidded on the concrete.
Anyone have a spare sump pan from a Gen 3 3S?
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Matty104 » Sun Sep 30, 2007 6:01 pm
fcuk, your lucky that wasnt your head that put the dent in it
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby RunningRich » Sun Sep 30, 2007 7:05 pm
I'd just pulled the axle stands out and started to lower it when it went.
Unfortunately Jap imports didn't have the oil level sensor (according to EPC) so I'll get the panelbeating hammer out tomorrow!
Richard
RunningRich
Postby rxtoy » Sun Sep 30, 2007 8:09 pm
if i had pictures of the x-rays of my ribs from when i dropped the front end of a civic on me (no engine or gearbox, just civic.................. was doing engine swap after sister's car threw a cambelt) i could top that. for stupidity at least. learnt my lesson from that one, always use axle stands now and sort of pedantic about making mates do the same thing.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby touge rolla » Sun Sep 30, 2007 9:00 pm
I'm guilty of that one. I know I shouldn't but I do.
Having said that I don't like to and if I'm taking more than one wheel off or it's going to be up for a while I'll throw some blocks underneath it. But for quick jobs I risk it
touge rolla
Postby FST4RD » Sun Sep 30, 2007 9:07 pm
Even if I take one wheel off to do the brake pads or change a tyre or something I chuck the wheel under the car I just took off...
Better to be safe then sorry....
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby thegreatestben » Sun Sep 30, 2007 9:10 pm
i've had an s13 on me for two minutes.
was lucky enough to come away with a cut on my hand despite having the sill across my body and the gearbox on my hand :oops:
don't take any chances any more :?
thegreatestben
Postby pidge » Sun Sep 30, 2007 9:29 pm
I:
- chock any wheels opposite the point I'm lift (e.g. I'll chock the wheels at the back of the car if I'm lifting the front)
- Use axles stands if I have them available, if I'm not just changing the tyre
- absent axle stands, a large chunk of wood (e.g. splitting block)
- and put a tyre (with rim!) under the side being lifted if I'm changing the tyre
- and stay clear of the car while raising or lowering.
I don't want 1000kg+ of car giving me a "gentle nudge"
pidge
Postby cogent » Sun Sep 30, 2007 9:37 pm
no matter which way you look at it, thats a crazy sump design.
cogent
Postby thegreatestben » Sun Sep 30, 2007 9:39 pm
pidge wrote:I don't want 1000kg+ of car giving me a "gentle nudge"
Its definatly a little more than a gentle nudge, but its not overly painful haha
thegreatestben
Postby ollieboy » Sun Sep 30, 2007 11:09 pm
My friend dropped his car on his head, I never actually worked out how he did it. We laugh about it now though
ollieboy
Postby Prymal » Sun Sep 30, 2007 11:30 pm
you still working on the blue beast rich ? When will we see that next - as we STILL need to get the NZ new group A's together for a meet
Prymal
Postby RunningRich » Mon Oct 01, 2007 8:28 am
cogent wrote:no matter which way you look at it, thats a crazy sump design.
The hole is for the oil level float (NZ new 3S only). The cut out in that part of the float is for the oil filter which comes off the sump. When you see it in the car it kinda makes sense.
One thing I learned out of this, grey gasket sealant does NOT stick to silver HPC coating. The aluminium sump was coated with HPC (waste of money). I undid the sump screw expecting to spend 20 minutes cutting the bastard off like when I rebuilt the engine. However just one tap made it drop off and covered me with the remnants of the oil. :x
Richard
RunningRich
Postby RunningRich » Mon Oct 01, 2007 8:34 am
classique71 wrote:you still working on the blue beast rich ? When will we see that next - as we STILL need to get the NZ new group A's together for a meet
I've taken a couple of days off work so decided to get a few things done. Only done about 2000kms in it this year, all open road.
I'm fixing the sump as noted. I thought that was where my oil leak was coming from, but closer inspection has shown a crap load of oil below the distributor. Bit hard to trace as it is so gunked. Also the turbo drain pipe has a lot of oil on it, probably from the temperature fitting I installed.
Also planning to remove the camshaft cover and drill it for Caldina ignitors. Will also retorque head studs.
Nothing major, it's done 60,000kms since the rebuild so time for a bit of maintenance!
Richard
RunningRich
Postby DeeCee » Mon Oct 01, 2007 9:11 am
dry sump it ;)
GT Four Adovansu
DeeCee
Postby Prymal » Mon Oct 01, 2007 5:42 pm
put the autronic on too >
I had a ride in franks Fresh rebuilt one - Very VERY nice and drivable .. t revs out like a honda :) Its basically the smae specs as what will end up in mine though ill try and aim for more response VS top end power :)
Prymal
Postby skoty » Mon Oct 01, 2007 7:22 pm
Yeah I always use axle stands if I'm doing something other than just changing a wheel obviously. Had a mate that had his beamer fall off a jack while he was under it. Amazingly a screwdriver somehow stabbed itself into the floor pan giving him the chance to escape for a cople of secs 8O He was lucky, most arn't.
skoty
Postby Racinghard » Tue Oct 02, 2007 9:59 am
Haven't learnt my lession yet at all... sort of changed motors in my corolla with only two sisser jacks.. :oops: I look back now and thought that i did notice that there was always a sway on when i was underneath it but being a dumb teen, didn't care hahaha (man i dont thing im all there yet)
At lest it's not a Honda
Racinghard
