tsoob wrote:i was told from a mechanic that with my microtech ecu i will need to run resistors is that right? because they are a low resistance injector ??
matt dunn wrote:I have had problems where the link's had troube starting if the ECU power is fed direct from the key along with too many other accessories, and the starter is too,
strx7 wrote:matt dunn wrote:I have had problems where the link's had troube starting if the ECU power is fed direct from the key along with too many other accessories, and the starter is too,
i've seen that too on a v8 hilux conversion
Users browsing this forum: Bing [Bot] and 24 guests
