dash lights not working
Postby fx gt » Sun Oct 07, 2007 10:49 pm
doing a 4age conversion in a corolla wagon
wndering what would cause the dash lights,number plate lights and frount couner lamps to not work?
t
head lights are working sweet
fx gt
Postby Alex B » Sun Oct 07, 2007 11:10 pm
A blown tail light fuse, installed a headunit while you was at it?? Did you use the green wire as the earth?
Postby fx gt » Mon Oct 08, 2007 11:16 am
nope :P
just trying to get stuff working in the car so far and this is one of the things that aint going :)
fx gt
Postby RunningRich » Mon Oct 08, 2007 12:04 pm
I had that issue in my old Celica Supra and it was a sick tail light relay. They would be on for 10 minutes, off for 10 minutes, on for 10 minutes...
Richard
http://gtfour.supras.org.nz
RunningRich
Postby fx gt » Mon Oct 08, 2007 12:50 pm
alrite thanks
where could i find that relay situated?
fx gt
Postby fx gt » Tue Oct 09, 2007 10:00 am
uppp
fx gt
Postby fx gt » Tue Oct 09, 2007 4:28 pm
$&#$% can i get a answer?
fx gt
Postby thegreatestben » Tue Oct 09, 2007 4:30 pm
try the fuse/relay areas. under the bonnet and the drivers kick panel.
thegreatestben
Postby fx gt » Tue Oct 09, 2007 5:15 pm
tgb.mr2 wrote:try the fuse/relay areas. under the bonnet and the drivers kick panel.
have replaced all the engine bay fuses/relays.checked inside ones once bt will check again.the indicators are working but no lights working on dash as of yett..
fx gt
Postby fx gt » Wed Oct 10, 2007 1:23 pm
upp
fx gt
Postby matt dunn » Wed Oct 10, 2007 8:05 pm
What model of corolla wagon?
If it's an early RWD model they used to have an extra park light switch on the dash, KE70's etc had them above the stereo of by the rear demister sw etc etc.
If the switch is missing or unplugged, you get some of the lights not working, but usually only the exterior lights stop.
Postby fx gt » Wed Oct 10, 2007 8:53 pm
ae92 fwd :)
fx gt
Postby fx gt » Thu Oct 11, 2007 2:35 pm
thinking the whole dash cluster might be $&#$% so going to try another one as it has pwer at the back of it.
fx gt
