engine whine help
engine whine help
Postby slammed_integral » Sat Oct 20, 2007 1:13 am
im getting a real annoying engine whine in my rear speakers and it gets higher pitched as revs increase. all i have is a aftermarket headunit with built in cd stacker and stock speakers.
wat should i do?
http://www.cardomain.com/id/slick_ep
there is nothing sour cola worms cant fix...
slammed_integral
Postby hsmidy » Sat Oct 20, 2007 8:42 am
you should have a supersser hooked up to ya alternater, that might have gone out the window
hsmidy
Postby B1NZ » Sat Oct 20, 2007 6:39 pm
Try rerunning the speaker cable to the rear if it's not stock, Usually the power wires for the car run along the drivers side, If someone has run speaker wire down there along next to the power wires that can happen, If this is the case rip them out and re-run them along the passengers side.
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby tsoob » Sat Oct 20, 2007 8:09 pm
is usually a dodgy earth some where in the car, what you are hearing is "road noise" as b1nz says check your speaker wires and re run them away from any main power sources.
tsoob
Postby Alex B » Sat Oct 20, 2007 8:50 pm
Although reccomended to seperate your power/speaker wires, i run my RCA/power and speaker wires through one gromet to the frunk in the MR2 with out white noise issue. Rear speakers arnt amped from factory or anything? What brand headunit?
