by RS13 » Sun Oct 21, 2007 9:59 pm
Adamal wrote:Just get a Rotax engine. They're designed for high altitude and low density air.
Seconded. Trust me, this may end up being the easiest option. Adapting any automotive gear to aviation involves a lengthly and costly certification process, I'm not 100% sure about regulations for microlights but I'd imagine them to be similar for light aircraft.
Rotax engines are reliable, small and lightweight, however everything in aviation costs considerably more due to the safety factor inbuilt into parts.. and you won't have to mess around with reduction gearing or anything to get the rpm you want.
Redmist wrote: A VW H engine is where you want to head. They have been used in aircraft applications for years and have aviation kits available for them.
Yup, I would look into these as well, I've seen these around for years, we rebuild them at course (I'm a trainee aircraft engineer).
