gasman wrote:can we push the closing date any earlier? i want to get mine a bit sooner than dec. cant we use stock air intake temp sensor with the link?
bluemaumau wrote:if your running a EBC you will need a boost control solinoid from what i gather, can anyone confrim?
gasman wrote:how hard was it to get the link controlling the boost correctly?
would be quite handy because then you cold do boost per gear or low boost when cold unless that a feature only found on the linkplus
~SlideWays~ wrote:
But as I said, this is a "G1". The G3 may be a different story.
~SlideWays~ wrote:Pretty hard..considering it never has been able to hold a constant psi. This was done my Andre Simon and he tried a couple of times. Its ok normally but when its cold weather and/or I'm pushing it at the track, it just keeps hitting boost cut...which aint fun
He did say from the get go that Link's are'nt any good at boost control.
matt dunn wrote:The new G3 is open loop only so far, and will work really well as long as the car has a wastegate that works properly.
and you can run a dash mounted boost knob, or gear dependant or whatever you want.
Users browsing this forum: No registered users and 42 guests
