stupid estima van ?'s......
Postby Defective » Sat Oct 27, 2007 7:40 pm
ok, a little out there but,
i read somewhere that some estima vans come with a 2.4 supercharged 4 cylinder engine... is this correct? and if so, are the engines any good?
and they are front wheel drive arent they?
could be a different sort of swap in my ae111...
but im thinking i either read it wrong, or its a diesel or something dumb like that lol
Defective
Postby Brick » Sat Oct 27, 2007 7:41 pm
yes some do, they have the sc14 supercharger
thats all i know :lol:
Brick
I know Kung Fu
Postby the fallen303 » Sat Oct 27, 2007 7:48 pm
rwd, not front
and yes they are good, dads got one, going mint! don't see it fitting in an ae111 though...
true house of JZ
Stay true to the origin
the fallen303
Postby Defective » Sat Oct 27, 2007 7:54 pm
hmm, i always thought they were fronters.... ah well, screw that then lol.
just an idea 8)
Defective
Postby Quirky » Sat Oct 27, 2007 8:21 pm
I use to own one of those but the 2.4ltr petrol one.
Bloody awesome for skids.
Hello There
Quirky
Postby frost » Sat Oct 27, 2007 11:01 pm
i hope you realize the engine sits horizontal rather then vertical.
Postby sergei » Sat Oct 27, 2007 11:11 pm
and some of them are 4WD.
All widebody are supercharged (and vice versa).
Postby andyztouring » Sun Oct 28, 2007 9:05 am
Some of the widebodies dont have superchargers,ie NZ Previas(same car different name)
andyztouring
Postby strx7 » Sun Oct 28, 2007 3:11 pm
the 10 and 20 series Previa/estime/Emina rady rady are RWD and 4WD, the 30 series which is around 99+ i think are fwd.
Postby YeMs » Mon Oct 29, 2007 12:52 pm
strx7 wrote:the 10 and 20 series Previa/estime/Emina rady rady are RWD and 4WD, the 30 series which is around 99+ i think are fwd.
yeh fwd, and im pretty sure they are V6.
yuck, hate the thought of those vans. worked on too many maori/islander transporters and they are filled with cockroaches. *dry reaches*
Your local Hybrid Elite tech
YeMs
Postby strx7 » Mon Oct 29, 2007 7:36 pm
some use the same motor as the new shape rav4's the 2.4l 4 cylinder vvti motor the other uses the 3.5 1GRFE motor which i think is rated around 200kw in the estima. its rated at 207 in the Aurion etc.
