ce106 corolla diff
ce106 corolla diff
Postby SpeedRacer » Sun Nov 04, 2007 7:13 pm
hey, what code is the diff in a 4wd corolla? is it a T series? as in ae86 diff/ will bolt up to a t-50?
also how hard would it be to put in a starlet? (needs spring mounts and discs :( )
Sinister Sleeper 35
SpeedRacer
Postby strx7 » Sun Nov 04, 2007 7:44 pm
I play with AE104 sprinters, 4wd 4AFE powered. the diff are the same size as ST185 GT4 ones, they aren't big by any stretch. They are IRS, are CE106 diff live rear set up?
Postby SpeedRacer » Sun Nov 04, 2007 9:51 pm
yea, live setup.
I just dont want to let this one go and find out that I had a good diff :(
u rekon it would handle a 4age turbo or nah?
Sinister Sleeper 35
SpeedRacer
Postby Mr Revhead » Sun Nov 04, 2007 10:00 pm
whats the trans code on the build plate? or do you not have that?
Postby frost » Sun Nov 04, 2007 10:04 pm
i heard a story that the torsion diff from the ST185 GT4 can fit a t series diff,
so it could be a good diff after all,
to put any diff into a starlet you need to cut off the mounts and reweld them in the right place, and that takes a bit of time a measuring if you dont know any one with a jig,
Postby SpeedRacer » Sun Nov 04, 2007 10:17 pm
e59f -14b
hmm... so im guessing an e59 4wd gearbox with f series drive line?
Sinister Sleeper 35
SpeedRacer
Postby Mr Revhead » Tue Nov 06, 2007 9:36 am
you sure its not a ce109?
Postby strx7 » Tue Nov 06, 2007 12:26 pm
E59F means its a 4wd E59 box
F means 4wd
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
