ae82 rear hub measurements needed!!
Postby Bazda » Wed Nov 14, 2007 8:07 pm
as topic sais, the distance between the 2 holes that the big bolts go through where it connects to the shock absorber.
centre to centre.
thanks
Postby strx7 » Thu Nov 15, 2007 6:36 am
same as 2wd 90 series & 100 series.
90's and 100's have the same top hats, 80 series is different top hat
Postby Bazda » Thu Nov 15, 2007 7:38 am
strx7 wrote:same as 2wd 90 series & 100 series.
I dont think you understand what im asking for.
yes I know ae92/101/111 share teh same top hat front and rear along with the bottom mounting points to the hub.
the ae82 has a 4 bolt top hat for the front where the ae92 etc has a 3 bolt.
The ae82 rear top hat has a different dimension 3 bolt pattern over the ae92 etc.
The ae82 front hub is the same as the ae92 etc
the ae82 rear hub is different to the ae92 etc, the hole distance is like 10-14mm difference, this is the measurement I need.
Postby Distrb » Thu Nov 15, 2007 8:36 am
will grab my verniers and take some measurements when i get home
Distrb
Regular Poster
Postby strx7 » Sun Nov 18, 2007 10:49 am
I personally - on a mates car have unbolted a std AE82 rear strut, changed the top hat onto an AE92 strut and bolted it back into the AE82. Are you saying it must have had AE92 rear hubs in it?
hub
Postby fxgt race » Sun Nov 18, 2007 11:03 am
you would be looking at 65mm,ae82 rear hub hole centres
fxgt race
Re: hub
Postby Bazda » Sun Nov 18, 2007 11:04 am
fxgt race wrote:you would be looking at 65mm,ae82 rear hub hole centres
cheers, all sorted now.
