Blacktop vs Silvertop, definitive guide.
Postby 10k 20v » Fri Oct 29, 2004 6:15 pm
the front engine mount is differnt but can be swapped over if you have both. remember the g/box housings are the same and thats where the other three mounts are.
10k 20v
Postby AE25 » Sun Nov 18, 2007 11:40 pm
oil pump housing on front of engine is different, has extra mounts for hydraulic tensioner on BT. the lower and middle cam belt covers are also different in the area just below water pump because of this (one bolt in different spot)
anyone know if the oil pump itself is interchangeable... different size at all?
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Postby matt dunn » Mon Nov 19, 2007 12:26 am
yeah as said above,
the oil pump is different as the BT has the hydraulic tensioner which sits in a slighlty different postion,
And cant run a RWD Alt bracket as it hits on the tensioner,
Blacktop Cambelt is one tooth longer,
cant run ST water pump on a Blacktop as the tensioner wheel hits on the housing, can be fixed with a hacksaw or grinder,
Blacktop centre cambelt cover does not match up with a ST waterpump,
they have different castings,.
So,
If you run a blacktop oil pump,
you must ran a blacktop water pump to fit.
If you run a blacktop water pump
you must use a BT cambelt covers.
Postby AceSniper » Mon Nov 19, 2007 12:27 am
the internal gears of the oil pump are the same, alloy housing isnt, also the waterpump differs
AceSniper
