SARD Fuel Pressure Regulator
Postby 2jayzgte » Mon Nov 19, 2007 8:59 pm
Just wondering if anyone know's the difference in SPEC between a normal and the RJ spec SARD FPR.
Also how can you tell the difference between a real deal SARD FPR against a chinese knock-off.I'm just interested in some things to look for when I buy one.
Basically I want to bin my Malpassi rising rate regulator and go back to the SARD item which is a 1to1.I have also bought a Apexi SAFC 2 I just want to get my fuel dialled precisely.Any thoughts or feed-back with those who have used any one of these items would be appreciated or any problems to look out for.
2jayzgte
Postby IH8TEC » Mon Nov 19, 2007 9:16 pm
get an aeromotive one, very reputable brand, and not that expensive.
this is where i got mine from
http://www.suprastore.com/aefuprre.html
Postby MRDRFT » Mon Nov 19, 2007 9:48 pm
IH8TEC wrote:get an aeromotive one, very reputable brand, and not that expensive.
if i send you the money bro could you get me one of these as im only young and dont have a credit card?
1992 toyota supra 1JZ power
210kw atw on 12psi
1999 nissan silvia drift car,
223kw atw on 12psi
MRDRFT
Postby neo » Mon Nov 19, 2007 11:25 pm
go to NZ post and buy ya self a credit card..
neo
Postby 2jayzgte » Tue Nov 20, 2007 7:43 am
To be honest I have heard a few bad things about Suprastore.com and its owner Mark Tozer over the years so I'd rather not go there.While Aeromotive maybe a reputable brand I think I might stick with SARD they may cost a little more but I'm not to worried about that as long as I get a real deal SARD FPR I think I'll be sweet.
2jayzgte
Postby postfach » Tue Nov 20, 2007 5:06 pm
you can tell the difference between a real sard and a fake one because a real sard comes in a blue sard box, with instructions in japanese with sard written all over them, and the regulator has a sard sticker on it, where the fake one will say something dumb like "d1 spec mega ultra adjustable fuel pressure regulator" on it.
buying from a reputable dealer helps, too. i bought mine from advanced automotive (yes, i know, they have a tendancy to charge "a little" extra) because they are about 5 buildings down from my work, it ended up being about $10 more than the ones on trademe, i bought the little gauge to go along with it, otherwise setting it up would be basically impossible.
postfach
Postby AE82 FXGT » Tue Nov 20, 2007 5:57 pm
Sard ones also don't come with a gauge like many of the cheaper ones do.
Your supposed to hook a gauge up set the pressure then take the gauge off for a cleaner look.
Don't know the difference between reg Sard an Sard type RJ.
Would like to know because I have an RJ want to know!
AE82 FXGT
Postby Crampy » Tue Nov 20, 2007 6:07 pm
Taken from nzkw.com (below).
Not sure if the RJ you refer to is the race one or not, but could be.
Measure your RJ one and compare to the below dimensions.
SARD FRP Sport - Regulator size 50mm x 96mm. Ideal for most vehicles up to ~ 450ps.
SARD FRP Race - Regulator size 66mm x 92mm. For high power applications over 500ps.????
Crampy
Re: SARD Fuel Pressure Regulator
Postby Crampy » Tue Nov 20, 2007 6:09 pm
2jayzgte wrote:Basically I want to bin my Malpassi rising rate regulator and go back to the SARD item which is a 1to1.I have also bought a Apexi SAFC 2 I just want to get my fuel dialled precisely.Any thoughts or feed-back with those who have used any one of these items would be appreciated or any problems to look out for.
What ratio is your Malpassi? Won't it be a 1:1 ratio as well? Or did you buy one with a higher ratio like 4:1 or 8:1?
Crampy
Postby bluemaumau » Tue Nov 20, 2007 6:41 pm
yea its the guage which makes genuine ones more expensive
cheap ones have cruddy guages
Postby Caveman » Tue Nov 20, 2007 8:21 pm
best way to get a genuine sard, buy from a proper shop!
type RJ is for higher flow rates (more hp). standard is good for around 400HP.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby 2jayzgte » Tue Nov 20, 2007 9:43 pm
I think the Malpassi rising rate regulator was 1.something to 1 I was a little unsure on that to be honest but I know its not 1 to 1.
2jayzgte
Postby Crampy » Wed Nov 21, 2007 7:51 am
Why not use your Malpassi ans the SAFC to fine tune the fuel? Malpassi is a good brand and you're not running the risk of buying a dodgey fake Sard jobbie.
Crampy
Postby Crampy » Wed Nov 21, 2007 7:53 am
Crampy
Postby Lith » Wed Nov 21, 2007 10:04 am
2jayzgte wrote:I have also bought a Apexi SAFC 2 I just want to get my fuel dialled precisely.Any thoughts or feed-back with those who have used any one of these items would be appreciated or any problems to look out for.
The S-AFC doesn't really adjust fuel, it just tricks the ECU into thinking the engines under less or more load than it really is under. The catch with that is where you lean it out, its potentially also adding timing - and vice versa when you richen it. Its quite a rough way of doing things...
2007 Mazdaspeed Axela
Lith
Postby cogent » Wed Nov 21, 2007 11:31 am
The way i see it is the S-AFC is more a supplement for helping run larger injectors, along with any ballast packs etc. Shouldn't really be used as a tool for tuning a largely stock fuel system.
cogent
Postby Crampy » Wed Nov 21, 2007 12:29 pm
Well I see the SAFC as being a piggy back that can be used for fine tuning of a lightly modified car. Eg, doing the exhaust and intake and then fine tuning it to suit those mods.
If it's major mods, then I'd go for a full programmable ECU.
Crampy
Postby 2jayzgte » Wed Nov 21, 2007 2:31 pm
Thats what I have a lightly tuned car basically exhaust filter boost controller FMIC I just want it for fine tuning purpose's as already mentioned.I suppose I still could use the Malpassi FPR.But I have been told SARD FPR's are a very good product.I just want the fuel which is a little rich in the mid-range to be spot on and hence why I want to use the Apexi SAFC 2 to help with this.
2jayzgte
Postby Crampy » Wed Nov 21, 2007 4:07 pm
Well I'd say the SAFC will be perfect for it then. It's only small adjustments you'll be wanting, so as long as it's being checked for knock, it'll be sweet. I've heard of them wreaking havoc on the timing when big adjustments are done, but that wont be what you're doing.
Crampy
Postby Bazda » Wed Nov 21, 2007 5:23 pm
http://www.synapseengineering.com/
you could try one of the FPRs synapse make..
