IH8TEC wrote:get an aeromotive one, very reputable brand, and not that expensive.
this is where i got mine from
http://www.suprastore.com/aefuprre.html
2jayzgte wrote:Basically I want to bin my Malpassi rising rate regulator and go back to the SARD item which is a 1to1.I have also bought a Apexi SAFC 2 I just want to get my fuel dialled precisely.Any thoughts or feed-back with those who have used any one of these items would be appreciated or any problems to look out for.
Crampy wrote:2jayzgte wrote:Basically I want to bin my Malpassi rising rate regulator and go back to the SARD item which is a 1to1.I have also bought a Apexi SAFC 2 I just want to get my fuel dialled precisely.Any thoughts or feed-back with those who have used any one of these items would be appreciated or any problems to look out for.
What ratio is your Malpassi? Won't it be a 1:1 ratio as well? Or did you buy one with a higher ratio like 4:1 or 8:1?
2jayzgte wrote:I have also bought a Apexi SAFC 2 I just want to get my fuel dialled precisely.Any thoughts or feed-back with those who have used any one of these items would be appreciated or any problems to look out for.
Lith wrote:2jayzgte wrote:I have also bought a Apexi SAFC 2 I just want to get my fuel dialled precisely.Any thoughts or feed-back with those who have used any one of these items would be appreciated or any problems to look out for.
The S-AFC doesn't really adjust fuel, it just tricks the ECU into thinking the engines under less or more load than it really is under. The catch with that is where you lean it out, its potentially also adding timing - and vice versa when you richen it. Its quite a rough way of doing things...
