Supra help needed.
Supra help needed.
Postby suprakid » Thu Nov 22, 2007 9:14 pm
My supra (GA70 1986) has some little problems that need to be fixed:
1. I lock the door and then when i come back to it in the morning its unlocked, it's unlocking by itself, and i don't know how to fix it.
2. The Brake warning light on the dash is constantly lit, there's no bulb out, what wrong there?
Help me!
suprakid
Postby GTCRSHR » Thu Nov 22, 2007 9:18 pm
2nd is probaly a faulty ground some where
Nothing to see here ...
GTCRSHR
Postby MrOizo » Thu Nov 22, 2007 9:19 pm
not too sure on #1 but #2 there is a "brake light out" control box in the rear which tells lights up the light in the dash. - this gets some corrosion going on and makes it think there is one blown.
have a search on google - cant rememebr where i seen the details for it at the moment...
even join www.supraforums.com - awesome tech and all that stuff there :)
MrOizo
Toyspeed Legend
Postby deaf_rattle » Thu Nov 22, 2007 9:32 pm
MrOizo wrote:not too sure on #1 but #2 there is a "brake light out" control box in the rear which tells lights up the light in the dash. - this gets some corrosion going on and makes it think there is one blown.
yep, that will be your problem.
Postby Jason T » Thu Nov 22, 2007 9:58 pm
How to fix here
http://www.supras.com/06/techcenter/display.php?QID=54
http://www.supramania.com/forums/showthread.php?t=58560
Fixing Toyota's since '87
Jason T
Postby Looonie » Thu Nov 22, 2007 11:45 pm
If your brake warning light on the dash is permanently on and your handbrake is down, put some fluid in your master cylinder as they have a sensor which tells you when its low on fluid, activates the same light as the handbrake light.
As for the vehicle unlocking itself... it sounds like the rod would be slightly bent and isn't settling into the "locked" position properly and the tension is causing it to unlock again?
Is it just one door or both doors?
Rumple dee pumple dee doo...
Looonie
Postby Quint » Fri Nov 23, 2007 7:49 pm
For the second problem, your relay has shat itself (well, maybe), mine did the same, took me ages to figure it out :/
Quint
Users browsing this forum: No registered users and 45 guests
