4age 20valve - Cambelt Tensioner (idler tensioner)
Postby Zyros » Sun Dec 02, 2007 3:55 pm
Hey all, just putting on the waterpump, and doing the timming on my engine.
On the idler bearing, (cambelt tensioner), whats goes into this hole..
4age 20valve silvertop ae101.
Top right ;)
Obviously the little holes for the spring, middle is to bolt the tensioner on.
The other hole where it connects to the block has no thread for a bolt.
Zyros
Postby matt dunn » Sun Dec 02, 2007 5:44 pm
It's on upside down.
there is a part on the oil pump housing that goes in there.
Postby Zyros » Sun Dec 02, 2007 6:43 pm
matt dunn wrote:It's on upside down.
Sorry, i should of said that the photo is from google as an example.
Just wanting to know what goes through that hole to pivot it.
the part on the oil pump housing the bolt hole lines up to, doesnt have nethn in it.
Zyros
Postby matt dunn » Sun Dec 02, 2007 8:21 pm
it is not a bolt hole, there is no thread, it's just a locator dowell that is there for it to pivot on.
Postby Zyros » Sun Dec 02, 2007 9:14 pm
Ahk, well i dont have nething in that hole at all for it to even pivot on..
Just a blank hole which lines up with the bearing?
Do i leave it? Or am i pissing something which goes in there which i can buy?
Zyros
Postby matt dunn » Sun Dec 02, 2007 9:52 pm
There needs to be something there for it to pivot on.
Postby 85AW20v » Sun Dec 02, 2007 10:18 pm
And it might have dropped down around the crankshaft pulley somewhere. Have a good look around before putting it all back together. You don't want the dowel jamming things up.
See ya
Simon
85 MR2 20v
85AW20v
Postby JRS » Sun Dec 02, 2007 10:35 pm
the dowell will be there. the tnesioner in the image is installed backwards.
the fange witht he holes should eb facing the motor.
the dowel only sticks out 3 or 4 mm. it's highl unlikely that it's not there.
take a photo of your motor and post it here.
meh.....
JRS
Postby Zyros » Mon Dec 03, 2007 11:00 pm
Ill get a photot hopfully tomorrow, mine is on correctlly, its just that where the bearing lines up, its just hole, theres nothing comming out of it to pivot on, a hole which goes in about 1cm, no thread.
Zyros
