gmacrae wrote:grounded the grn/red and wht/blk AFM wires as the manual i've got says they're something to do with grounding with the circuit open relay (fuel pump) - no difference. sh*t this is confusing
Toymad wrote:gmacrae wrote:grounded the grn/red and wht/blk AFM wires as the manual i've got says they're something to do with grounding with the circuit open relay (fuel pump) - no difference. sh*t this is confusing
I've just done this swap and I'm sure I didn't ground the Green/Red wire. If you did, how are you getting the Circuit Open relay to engage for the fuel pump?? The Green/Red wire grounds through the AFM and in doing so, grounds the Circuit Open relay's coil for the fuel pump when it is not starting.
Make sense?
David
gmacrae wrote:Circuit open relay is not being used, couldnt quite work out how is was supposed to be rigged (still dont) so i just set up a normal relay to power the fuel pump. The fuel pump is definitely running (and was working fine 2 weeks ago).
