deaf_rattle wrote:silvertops do sound like diesels at the best of times, any chance of a audio clip of how yours sounds? its probably fine.
As for the idle, i had some problems with mine, but it seems to be timing related. have you checked tension on the cable?
HRT wrote:As Revhead says, they aren't really a noisy engine. The pulley if stuffed will make a bit of a noise which I found to be more noticeable at idle or very low revs than anything else. If it sounds like a diesel then something isn't quite right.
gmacrae wrote:How about the 3rd question.. anyone used a blacktop ecu and map sensor on their silvertop with good results?
sergei wrote:Black top and silver top have same sized injectors, very similar engines, and generally should run with either ECU setup no problem. You will not gain anything by running MAP system on AFM-ed engine or vice versa.
gmacrae wrote:sergei wrote:Black top and silver top have same sized injectors, very similar engines, and generally should run with either ECU setup no problem. You will not gain anything by running MAP system on AFM-ed engine or vice versa.
Thanks to your post about the injector differences Sergei, i just picked up some blacktop injectors for mineWill have them cleaned before they go in. I understand the small differences in cams etc and that changing to a map'd ecu will likely not gain anything at all (though with an safc or something, could def help)... i just want to let those itb's sing if it aint gonna cost much
