3sge into 3sf corona wagon
Postby levinguy » Sun Dec 30, 2007 4:59 pm
mate wanted me to ask..
putting a gen 1 3sge into a corona station wagon (ST171)
have used all the standard celica engine loom and most of it plugs in but have hooked battery up and only door lights work...
help.. what have i done wrong? or what havn't i done?
cheers,
levinguy
Postby RunningRich » Mon Dec 31, 2007 12:48 pm
Just because it plugs in that doesn't mean that the wiring at each plug is the same.
Have you compared the two wiring diagrams?
Richard
http://gtfour.supras.org.nz
RunningRich
Postby levinguy » Mon Dec 31, 2007 3:06 pm
RunningRich wrote:Just because it plugs in that doesn't mean that the wiring at each plug is the same.
I dont have the two wireing diograms... and cant find any for the corona on the net.
Has anyone been silly enough to do this before?
Its all ready to go minus the wireing
levinguy
Postby levinguy » Tue Jan 01, 2008 12:03 pm
No spark! dam it.
I have hooked up everything now and have everything working except it wont spark, and i cant find anything on the net that solves my problem,
i traced back another loom that i have but cant find the problem...
Could i just hook the ignighter and coil up directly/. and how would i do this
levinguy
How to manually hookup ignighter
Postby levinguy » Tue Jan 01, 2008 1:58 pm
Its all ready to go, just need a spark, does anyone know how to manually hook it up os that it would start, as u would when you dury riged it etc
levinguy
Postby KinLoud » Tue Jan 01, 2008 8:33 pm
Sounds like a worthy project.
Be patient, work your way through every little connection and recheck all your presumptions about what wire goes to where.
There is a chance that you can get a code out of the computer that might give a clue as to the problem.
Is there a signal going to the ignitor?
Are all the plugs plugged in!
Make sure the ignitor is earthed - some toyota ignitors won't work if not earthed (don't know why)
Ken
Ham
021 408 863
Postby levinguy » Wed Jan 02, 2008 8:45 pm
mission succesfull
levinguy
Postby KinLoud » Wed Jan 02, 2008 8:53 pm
What was the problem?
Ken
Ham
021 408 863
Postby levinguy » Wed Jan 02, 2008 8:58 pm
b1 and batt had 12volts to them, b did not, they all are 12volt feeds to the ecu that are needed, its the simple things we miss...
now his car is going and mines not, figures..
levinguy
Postby levinguy » Thu Jan 03, 2008 9:46 pm
It has started, was running fine then it suddenly started running ruff, like its running on 3cl however iv checked all the plugs and changed them, changed the leades, and then pulled out the injector plugs 1 by 1 and the idal droped every time i pulled a plug so its getting fuell and a spark into the clinders so y wouldnt it run right...... especially sinc it was before, i fixed an oil leak and then it just started running like it
could it be the coil or dissy or igniter... perhaps a weak spark?
Please send me your knowledge, thanks,
Rob
levinguy
Postby Trls250s » Fri Jan 04, 2008 9:22 am
Timing?
Air Flow meter?
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby metric » Tue Jan 08, 2008 6:41 pm
what fuel pump are you running if you dont mind me asking?
metric
Postby levinguy » Tue Jan 08, 2008 6:54 pm
think he's using a holden commadore vl fuel pump
levinguy
Users browsing this forum: Google [Bot] and 29 guests
