altezza clutch
altezza clutch
Postby sk1dlet » Mon Jan 07, 2008 5:00 pm
hey guys im in need of sum info on the clutch on my altezza
it's a 1998 rs200 3sge beams my release bearing is starting to rattle loudly on idle so im thinking i may as well replace the whole clutch
what i would like to know is
1 some people say you need to replace the flywheel as well is this true?
2 do you guys know of anyone that could give me a good deal on a
new clutch setup?
dylan
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
sk1dlet
Postby Zak » Mon Jan 07, 2008 5:03 pm
You don't have to replace the fly wheel, but you can't machine it, so if it's in poor condition then you have no choice.
Best way to do it, as a fly wheel is $1000+ is to get a TRD or other aftermarket fly wheel and clutch, it will probably work out cheaper, and you'll get a better clutch too.
Zak
Postby Ae92typeX » Mon Jan 07, 2008 5:18 pm
Zak wrote:You don't have to replace the fly wheel, but you can't machine it, so if it's in poor condition then you have no choice.
what cant the tezza beams flywheels be machined?
Ae92typeX
Postby Zak » Mon Jan 07, 2008 5:45 pm
It's a dual mass fly wheel, you can turn the machined suface about 30 degrees by hand. It has all the springs and dampers in the flywheel insted of the clutch plate. There isn't really any way to hold the fly wheel to machine it because the ring gear and center aren't directly attached to the surface that needs to be machined.
The TRD fly wheel however is a normal type, with a sprung clutch plate.
Zak
Postby Quint » Mon Jan 07, 2008 6:07 pm
why the hell would they do that?
Clutchs are consumables O_o. It'd be like makeing your brake discs non-machinable.
Quint
Postby Zak » Mon Jan 07, 2008 6:20 pm
Quite alot of the rotors now are one use too, the amount of lexus rotors we have sitting out the back of work is shocking.
Mind you, alot of the euros are just as bad.
Zak
Postby d1 mule » Mon Jan 07, 2008 6:41 pm
[quote="Quint"]why the hell would they do that?
quote]
to make the clutch feel less ah brutal, its a kind of dampening thingy, S15 silvias have them too.
on my mates drift s13 (s15 engine + box) they just welded the rotating bit then machined it, cuz with the dual mass it wouldnt clutch kick as teh fly absorbed most of the shock. prob not the best way of doing it.
places like BNT sell a selected range of replacement flys
d1 mule
Postby Lloyd » Mon Jan 07, 2008 6:42 pm
Hilux/Surfs are awesome for those flywheels stuffing themselves and getting noisy. Toyota do solid flywheels and clutch setups for them, surely they have a solid option for the Tezzas too?
Chances are it wont need one anyway, just chuck a kit at it
Postby sk1dlet » Mon Jan 07, 2008 6:52 pm
cool cheers for the insight peoples
hopefully i can hold of on needing to do it for a bit as i need to get my starlet on the road
98 RS200 ALTEZZA
sk1dlet
Postby Zak » Mon Jan 07, 2008 7:26 pm
Just be carefull you don't drive it round slipping to minimize any damage to the fly wheel. That way you should be able to just replace the clutch and not the fly wheel too.
Zak
Postby LEV_101 » Tue Jan 08, 2008 2:00 pm
if you have the money please replace the dual mass flywheel.
its 15kgs (dual mass) vs 5-6kg (solid)
it goes so much better.
LEV_101
Postby Mr Revhead » Tue Jan 08, 2008 2:49 pm
HRT wrote:Hilux/Surfs are awesome for those flywheels stuffing themselves and getting noisy. Toyota do solid flywheels and clutch setups for them, surely they have a solid option for the Tezzas too?
sort of.... a kit and flywheel from other models will fit
but theres no specific "dual mass to solid" kit.
and the same cant be done for the altezza as the flywheel is so deep.
best option is to fit a TRD one if you dont like the stock set up
