FST4RD wrote:You would want 2 small 16g's if you were going down that path, but even then it would be kinda laggy.
The 2.5 legnums and that run 1 evo 4+ turbo with good results or 2 x TD04's of GSRs.
strx7 wrote:are you allowed to run water injection?
strx7 wrote:Personally i'd look at running a pair of TD05H's on it, Evo1-3 exhuast housing
they'd be good for somewhere in the vacinity of 650-700HP. with high compression they'd spool fairly quick. Fairly small turbo physical size wise so you'd have less issues fitting them in. easy to get parts for, easy to upgrade, relitively easy to source aswell
RedMist wrote:The GT255r looks like a very suitable turbo. However I'm probably (dependant on response) going to run antilag. I dont really want a turbo that will costs lots to purchase and support.
I'm leaning towards a set of TD04's, but still need to do a tonne of research.
One thing of curiousity is how the hell I load balance the turbos? The LinkPlus G3 only supports one boost control solinoid.
bbq1988 wrote:looked into superchargers for instant response?
barryogen wrote:bbq1988 wrote:looked into superchargers for instant response?
for the curve, and wide band of power he is looking for it'd probably be very cost prohibitive to go to an SC.
RedMist wrote:Bingo.
RedMist wrote:barryogen wrote:bbq1988 wrote:looked into superchargers for instant response?
Bingo.
There are several SC kits for the VQ, however they are expensive, and all dont appear to produce anything over 350hp.
bbq1988 wrote:RedMist wrote:barryogen wrote:bbq1988 wrote:looked into superchargers for instant response?
Bingo.
Just a thought
Users browsing this forum: Bing [Bot] and 2 guests
