4age engine squel!
4age engine squel!
Postby fx gt » Sun Jan 13, 2008 10:33 pm
on the way home today the fxgt started squeling so pulled over and got a tow home
took the fan belt of and started it again.made the same noise. so is nothink to do with fan belt. going to take the altenator/water pump belt of tomorrow and see if it still makes the noise. could it be waterpump making that kinda noise? or maby altenator?
would anyone have a diagram as to take the belt of. and water/altenator pics.how there mounted/bolts
car is ae92 fxgt redtop tvis
fx gt
Postby Alex B » Sun Jan 13, 2008 10:42 pm
Fan belt on those goes to the alternator and water pump correct? Well if you took that off and it still made the same noise you might want to start looking elsewhere.
Postby fx gt » Sun Jan 13, 2008 10:59 pm
oh
i just assumed fanbelt was the one that goes around aircon and powersteer
have i got it rong?
fx gt
Postby Alex B » Sun Jan 13, 2008 11:04 pm
Well they don't really have a "fanbelt" as such, there are belts to drive A/C, P/S alternator etc. Drop one off and see if the noise stops. If not then drop the next one off and see if the noise stops (this is assuming you checked the belts were tight and not the source of noise for that reason)
Postby fuzzilogyc » Mon Jan 14, 2008 8:19 pm
the one that drives the AC and powersteer is a regular culprit. it will be in a loop of 3 pulleys with one tensioner pulley. the loop is the one closest to the front of the engine. to loosen loosen off the bolt on the front of the tensioner then undo the bolt on top of the tensioner. its piss easy
fuzzilogyc
Postby 20v_rollaboy » Mon Jan 14, 2008 9:09 pm
Just remember if you take the belt off that runs the water pump and alternator, don't let it run for too long as the water pump wont be pumping :wink:
20v_rollaboy
Postby fx gt » Mon Jan 14, 2008 9:11 pm
water pump seized is the problem :(
fx gt
Postby Trls250s » Tue Jan 15, 2008 12:45 pm
Yea seized water pump will make your belt squeal alright.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
