fangsport wrote:you will more than likely need to cut the section of firewall where the steering shaft comes through and swap it for the donor.
box steering comes out straight, whereas the rack steering comes through on quite an angle
yeah steering box will mount to the chassis, but i dont think you need to mod the firewall?
a r&p steering column including the mount should put it in the right place, you may need to drill holes for the mount, and you may need the plastic cowls as well (but im not sure on that bit) you may also need the r&p brake pedal as the coloum runs in a slightly different angle as fangsport mentioned
you will need a r7P cross member. i dont know if the steering arms are the same or not.... i have some KE70 steering arms if you need some.
while it wil take a little bit of work, i dont thinks its a drasticly hard job... but very worth imo
