removal of quad throttles and fuel rail from 20v head
Postby xsspeed » Sun Jan 20, 2008 2:51 pm
hey guys my search yielded very little in what i am after,
im tryna pull off the quad throttle from this 20v 4age head i have,
i have undone the 4 or so bolts and two nuts that connect to the head itself and removed the bracket that bolts to the block but now i cant get the throttle bodies too budge. have i left something still attache or is that rubber gasket a bitch to peel back?
any recommendations im all ears
cheers guys
Postby xsspeed » Sun Jan 20, 2008 8:16 pm
anyone?
Postby AceSniper » Sun Jan 20, 2008 9:00 pm
there is like 8-10 nuts/bolts total... off the top of my head there at the top and below
AceSniper
Postby flygt4 » Sun Jan 20, 2008 9:53 pm
4 top and 4 below i think? bottom ones are an ass to get to.they are inbetween the throttles.
if someones used sealant on the manifold it m ight need a bit of a wiggle.
flygt4
Postby xsspeed » Mon Jan 21, 2008 12:39 am
yeah there are 8 i think, couldnt remember how many i pulled off, any particular knack to getting it free?
Postby matt dunn » Mon Jan 21, 2008 10:12 pm
xsspeed wrote:yeah there are 8 i think, couldnt remember how many i pulled off, any particular knack to getting it free?
There are nine. 5 on the top, 4 on the bottom.
and then they just fall off. never had one stick on??
Postby try_hard » Mon Jan 21, 2008 10:39 pm
AE92 Trueno Sprinter 4AGZE
try_hard
Postby xsspeed » Mon Jan 21, 2008 11:07 pm
ok might have missed the middle one on the top :D how do you get to that?
Postby Bling » Mon Jan 21, 2008 11:20 pm
if you can't see it at all you may have a problem :lol:
otherwise its just a case of thinking outside the square, nothing is ever easy. I'd go look at mine but its rather dark, so if you still haven't worked it out 2moro night i'll have a look
Postby matt dunn » Tue Jan 22, 2008 12:26 am
xsspeed wrote:ok might have missed the middle one on the top :D how do you get to that?
the bar from the throttle spring on top to the throttles pushes off and out of the way and just use a tube socket....
Postby xsspeed » Sat Jan 26, 2008 6:05 pm
ok so went and had another go, but cant seem to get to the middle 3 on the top (fuel rail side) i havent taken the air plenum off should i be doing that to get to these 1s?
Postby xsspeed » Sun Jan 27, 2008 2:20 pm
up???
Postby flygt4 » Sun Jan 27, 2008 4:52 pm
maybe post a pic of the issue you're having?
i've never really had too much trouble getting mine off, just need the right tools to get the bolts out and it should practically fall of.
flygt4
Postby xsspeed » Sun Jan 27, 2008 8:13 pm
ok i got it, needed to take the plenum off to get through to them,
