At last 10s
Postby postfach » Sat Jan 26, 2008 11:52 pm
Bazda wrote:haha
its a bit different when ur backing off to do a 10 8O
braking, even :o
postfach
Postby audi man » Sun Jan 27, 2008 6:51 pm
Back from the nats, was a good day but not for the supra first run no traction of the line as the track was still damp and we had a bad miss as i was eating spark plugs but we did a 10.7 @ 190KMS, on my 3rd run i smashed my diff doing a burn out, but i do know there is a 9sec pass in her but its getting it right.
1.5 jz mk3 supra,675rwkws at 28psi and 723rwkws at 32psi
audi man
Postby Lith » Sun Jan 27, 2008 6:59 pm
Bummer. 10.7 is nothing to be sneezed at though - any noteable times from other cars there?
2007 Mazdaspeed Axela
Lith
Postby AceSniper » Sun Jan 27, 2008 9:01 pm
7.4 rayglass?
AceSniper
Postby Bazda » Sun Jan 27, 2008 10:35 pm
yea rayglass did soemthing like that time.
I was wanting to see that full pass run of yorus john!
put u in another class then ur car starts giving problems :S
Postby 2jayzgte » Mon Jan 28, 2008 7:22 am
audi man wrote:Back from the nats, was a good day but not for the supra first run no traction of the line as the track was still damp and we had a bad miss as i was eating spark plugs but we did a 10.7 @ 190KMS, on my 3rd run i smashed my diff doing a burn out, but i do know there is a 9sec pass in her but its getting it right.
Good stuff John a new diff I think I heard 10.7 you must be laughing.
Your cars probably good for a 9.7 once fully soughted what are you going to do about you breaking diffs I no Graeme@ Croydon's was having similar problems when he was at the same stage with his car about 3-4 years ago.
I heard Rayglass was doing 1.0 60 footers F**K Me sounds like 6 second material to me
2jayzgte
Postby audi man » Mon Jan 28, 2008 12:46 pm
As any one tryed a trd diff, and would you think thay would be stronger than a torsan.
audi man
Postby 2jayzgte » Mon Jan 28, 2008 5:58 pm
audi man wrote:As any one tryed a trd diff, and would you think thay would be stronger than a torsan.
I no Graeme and Justin were using the small auto diffs and they are'nt up to the power you guys are making I no Justin has just bought a Big Torsen diff from a friend down here I personally don't think it will fear much better with 7000 rpm launches and all.
2jayzgte
Postby deaf_rattle » Mon Jan 28, 2008 6:14 pm
how about a true trac? they are supposed to be very good.
they do the detroit lockers as well, which would be more than up to the task.
Postby RH9 » Mon Jan 28, 2008 6:24 pm
Pretty sure Graeme broke 2 Cusco LSD's - in the end Joe fitted a different kind of diff altogether but then the engine broke :cry:
2003 TRD Vitz RS Turbo - 160hp
2000 Toyota Aristo TTE - 490hp
1991 Skyline GTR - 720hp
www.gtr-elite.com
www.sthitec.co.nz
RH9
Postby Cakky » Mon Jan 28, 2008 6:41 pm
anyway to fit a ford 9" in? can't break that lol :P
Cakky
Postby AceSniper » Mon Jan 28, 2008 7:44 pm
torsen.... why dont you goto a plate lsd?
AceSniper
Postby postfach » Mon Jan 28, 2008 7:52 pm
I went round there today. Previously hes split the head casing apart. This time I didn't see that (only had a quick look) but I think the half shafts have turned inside the head because one of them is stuck in there so tight they cut it off to remove it. The bolts that hold the crown wheel to the head have all sheared off. IMO not worth replacing with another factory diff since this is the 3rd or 4th time its happened (I think??), and I don't believe the type of diff head used will make a difference, since it's a shock/complete failure thing rather than a slipping/opening up issue.
postfach
Postby audi man » Tue Jan 29, 2008 1:05 pm
We opend the diff to find out that we riped the crown wheel of the torsan it self, not what i was hopping for, still looking at a 1.5 way trd diff.
audi man
Postby AceSniper » Tue Jan 29, 2008 6:04 pm
kazz cusco will be better than a TRD item, but by the sounds of it your crown and pinion will just fail then?
AceSniper
Postby BlakeNZ » Thu Jan 31, 2008 9:51 am
I have a trd 2 way diff, after cracking the torsen carrier housing. my viscious shift kitted auto was most likely the culprit. a lot of the big power supras in japan go to a TRD lsd,so i can assume they are stronger. however, it doesn't stop you breaking the pinion/crown wheel combo.(which i heard that the croydon supra did a couple of times.)
BlakeNZ
Postby audi man » Thu Jan 31, 2008 10:44 am
BlakeNZ wrote:I have a trd 2 way diff, after cracking the torsen carrier housing. my viscious shift kitted auto was most likely the culprit. a lot of the big power supras in japan go to a TRD lsd,so i can assume they are stronger. however, it doesn't stop you breaking the pinion/crown wheel combo.(which i heard that the croydon supra did a couple of times.)
Blake we have a trd diff on its way, i can only try it i do now the next thing to go will be the crown wheel and pinion and we are looking into that now.
audi man
Postby audi man » Tue Feb 05, 2008 5:55 pm
AceSniper wrote:torsen.... why dont you goto a plate lsd?
lol tryed a clutch lsd once, i got about half way down the strip befor all the clutches were soup.
audi man
Users browsing this forum: No registered users and 26 guests
