ive found one wire that if i hook a power source down it will turn over. but i can find the wire that turns on when i click the ingition switch on.
does any one know what i have to do to get it running.
ove tryed searching but couldfind anythink
20v_rollaboy wrote:What have you done with the selector plug that went to your auto box?
IIRC thats the only plug that needs to be modified. Sure you have plugged all other plugs back in?
Ae92typeX wrote:as above, have you bridged the neutral start switch/inhibitor. need to do that when going auto-manual but otherwise should be fine.
x-s-i-v wrote:
ive pluged everything back in except for the big plug that goes into the auto box. were just putting a screw driver into on of the pins and putting it on to the battery to start it
