how much to get extractors fitted?
Postby Grrrrrrr! » Mon Feb 04, 2008 9:56 pm
As someone else suggested you could buy THESE and get a custom 2-1 part fabricated.
They need the two outside holes slotted a bit to fit the 16v head. (about 15 minutes work with a die grinder with a good carbide bit)
http://www.trademe.co.nz/Browse/Listing ... =139181702
If you win that auction i can also sell you the 20v 2-1 section for $35 which means you would be able to cut the flanges off to make up your custom 2-1 section.
Grrrrrrr!
Postby Mr Revhead » Mon Feb 04, 2008 9:59 pm
i would recomend making a custom 2-1 section
the blacktop one is the biggest restriction in the stock ae111 system
Postby Bling » Mon Feb 04, 2008 10:05 pm
Would still want to get the 2-1 section tho is as Grrrrr! said, to make use of the flanges for a new 2-1.
Postby Jooce » Tue Feb 05, 2008 6:02 pm
sweet im keen
Jooce
